ePMP
The ePMP™ platform has set the standard for high performance, scalability and reliability at a compelling price.
ePMP Overview
The ePMP fixed wireless broadband platform offers affordable scalability and performance. Now in its fourth generation, millions of ePMP radios have been deployed around the world for more than a decade in both point-to-multipoint and point-to-point topologies. Service providers and network operators rely on Cambium’s superior interference mitigation, frequency reuse, and tailored air interface.
The latest generation, ePMP 4000 Series, offers backwards compatibility, while taking advantage of the latest 802.11ax standard and maintaining ePMP features such as TDD synchronization, SmartQoS, and frame optimization. Now available in the 6 GHz spectrum, the 4600 Series takes advantage of 850 MHz of new clean, low-noise spectrum. The ePMP 4500 offers the same technology in the 5 GHz frequency band.
Watch the latest ePMP fixed wireless broadband webinars.
Learn about 6 GHz & access the free AFC spectrum availability tool.
ePMP 4500 Series
Deliver high-performance, scalable, and reliable fixed wireless broadband with the ePMP 4500 series, powered by advanced 802.11ax technology. ePMP 4500 features:
  • 8×8 MU-MIMO for up to 4 Gbps in 5 GHz
  • Supports up to 120 subscriber modules
  • Ideal for dense deployments and enhanced interference mitigation
ePMP 4600 Series
Make the most of 6 GHz with the ePMP 4600 fixed wireless solution that delivers high-performance, scalable and reliable access points for fixed wireless broadband. ePMP 4600 features:
  • MU-MIMO for up to 4 Gbps in 6 GHz
  • Low TCO with three-year hardware warranty
  • Interoperable with all Force 4600 radios
Learn More about 6 GHz
Key Features
Multi User MIMO
Achieving higher throughput in the downlink is often solved by achieving higher modulation or wider channels. In both cases, the environment and interference prevents achieving higher modulations or operating in wider channel bandwidths. Multi-User MIMO technology (MUMIMO) simultaneously transmits to 2 subscribers in the downlink, thus doubling the throughput in the downlink.
Intelligent Filtering
As more transmitters are deployed, noise continues to be a critical factor in operation. While almost all radios have some type of filtering, many use static filters that block out only noise from outside of the radio’s total operating spectrum. While this provides a clear channel for operation, these systems still allow noise from neighboring channels to affect system performance. Cambium solutions use dynamic filtering with a static filter to block noise from outside of the operating spectrum and a dynamic filter to block out interference from adjacent channels. As the system changes to another channel, it automatically blocks out noise from adjacent channels to improve signal quality.
Frequency Reuse
By re-using frequencies when deployed in back-to-back configuration, a network operator can effectively use the same frequency twice to connect users. In large deployments, a network operator can connect thousands of users by reusing the same frequencies across the field service area, maximizing the use of available frequency and providing access to thousands of users in a small amount of spectrum.
GPS Synchronization
When networks become more dense, self-interference becomes an issue. GPS synchronization coordinates the entire network, reduces self-interference, and keeps network performance high as more subscribers are added.
Smart Beamforming and Beam Steering
As more emitters are deployed in the service area, it’s important to mitigate noise and interference to provide reliable high-speed connectivity. ePMP Access Points (AP) work in conjunction with the optional beam-steering antenna to create narrow beams in the uplink, which in turn improves the signal-to-noise ratio. Placed at the AP on a tower, the smart antenna creates tighter beams to connect with subscribers while nulling out radiation from unwanted emitters in the field.
Air Fairness
ePMP employs a sophisticated priority-based, air-fairness, starvation-avoidance algorithm for allocating RF resources to subscriber modules (SM). The allocations are based on airtime instead of throughput, thus avoiding the situation where SMs in poor RF conditions take up an excessive amount of time and, consequently, available capacity.
Estimate your ePMP capacity
ePMP 4000 Series
ePMP 6 GHz Force 4616 Series Subscriber Module
Gbps capacity leveraging 160 MHz channels and 802.11ax technology spanning from 5.925 GHz to 7.125 GHz.
6 GHz outdoor Details
ePMP 4600 6 GHz Fixed Wireless Access Point
Gbps capacity leveraging 160 MHz channels and 802.11ax technology spanning from 5.925 GHz to 7.125 GHz supports up to 120 subscribers.
ePMP 6 GHz Force 4600C Connectorized Fixed Wireless Subscriber Module
ePMP 6 GHz Force 4625 Fixed Wireless Subscriber Module
ePMP 4500 / 4500C / 4500L 5 GHz Fixed Wireless Access Point
Gbps capacity leveraging 80 MHz channels and 802.11ax technology spanning from 4910-6135 MHz. Integrated (4500) or Connectorized (4500C / 4500L) options available.
5 GHz outdoor Details
ePMP 5 GHz Force 4518 Series Fixed Wireless Subscriber Module
Multi-Gbps capacity leveraging 80 MHz channels and 802.11ax technology spanning from 5150–5920 MHz
ePMP 5 GHz Force 4525 Series Fixed Wireless Subscriber Module
ePMP Sector Antenna
With a compact design featuring integrated ePMP™ Access Point and ePMP 4500L Smart Antenna mounting and a very high front-to-back ratio of 35 dB and a wide frequency range.
Sub 6 GHz outdoor Details
Force 400 Series Point-to-Point
ePMP Force 400 Series
Cambium Networks' ePMP Force 400 Series point-to-point solution delivers up to 1 Gbps throughput, at a breakthrough price point based, on the latest 802.11ax standards.
4.9 GHz 5 GHz 6.4 GHz Sub 6 GHz outdoor Details
ePMP 3000
ePMP 3000
High-performance, scalable, and reliable access point for fixed wireless broadband, featuring MU-MIMO for up to 1.2 Gbps capacity for 120+ subscribers.
ePMP 3000 FSR 5.1–5.9 GH
The standard for high performance, scalability and reliability in harsh interference environments, all at a compelling price, interoperable with all Force 300 SMs and backwards-compatible.
ePMP 3000L
2x2 MIMO support with peak throughput of 600 Mbps; supports up to 65 subscriber modules. Connectorized for use with 90-/120-degree sector antennas.
4.9 GHz 5 GHz outdoor Details
ePMP 3000L FSR
2x2 MIMO connectorized access point that can support a wide variety of deployments, including 90/120 sectors, narrow sector horns, or even 360 omni coverage.
ePMP 3000 Sector Antenna
Cambium Networks has deployed more than fi ve million radios around the world achieving unparalleled degrees of scalability. Continuing the tradition of designing and manufacturing industry leading antenna solutions, the ePMP 3000 4X4 sector antenna encompasses all the key diff erentiations of the Cambium Antenna line and adds 4X4 Multi User MIMO Capability. Designed to work in 5 GHz spectrum and 90 degree coverage, the antenna is an integral part of the ePMP 3000 Access Point and allows for Multi User MIMO Operation.
ePMP Sector Antenna
Force 300 Series Subscriber Modules
ePMP Force 300-25
Cambium Networks’ ePMP Force 300-25 is designed to operate in high interference environments and provides superior throughput of over 500 Mbps of real user data.
ePMP Force 300-19R
Combining the latest 802.llac Wave 2 technology and the field proven scalable performance of ePMP, the Force 300-19R delivers up to 600 Mbps of capacity. The Force 300-19R is a powerful yet affordable subscriber module compatible with the ePMP3000 Access Point and using the forward compatibility features also interoperates with the ePMP 2000 to ease the migration into the 802.llac Wave 2 technology. The Force 300-19R has a 19 dbi integrated antenna with a narrow beamwidth and reliable IP67 mechanics.
ePMP Force 300-16
Force 300-16 continues the tradition of previous products with a horizontal orientation mount providing a 15 degree beamwidth and 16dBi gain, the F300-16 offers a compelling, compact subscriber or point to point solution resilient to interference and reliable mechanics. Supporting peak throughput greater than 500Mbps, the Force300-16 will also supports an always on spectrum analyzer and local WiFi management to take advantage of mobile installation applications.
ePMP Force 300 CSM FSR Subscriber Module
Offers high performance and low latency across both point-to-multipoint and point-to-point deployments.
ePMP L Series Subscriber Modules
ePMP Force 300-25L
Cambium Networks’ ePMP™ Force 300-25L is designed to operate in high interference environments and provides superior throughput of over 400 Mbps of real user data.
ePMP Force 300 CSML Connectorized Subscriber Module
Cambium Networks’ ePMP™ Force CSML is designed to operate in high interference environments and provides superior throughput of over 400 Mbps of real user data.
ePMP Force 200L
Wireless service providers and enterprises around the globe are challenged to deliver reliable connectivity in overcrowded RF environments. As spectrum increasingly becomes a scarce commodity, finding the right broadband connectivity solution is vital for all low and high density types of deployments.
ePMP Force 130 5 GHz
Resources
Documentation
  • ePMP 4000: Asymmetric Channel Bandwidth Explained
  • Smarter Uplink Performance with ePMP 4000
  • Real-World Demo: MU-MIMO Throughput on ePMP 4500 Network
  • ePMP 4600L 6 GHz Fixed Wireless Broadband Access Point Unboxing
  • ePMP 4625 6 GHz Fixed Wireless Unboxing and Installation
  • ePMP 4600C 6 GHz Fixed Wireless Broadband Reflector Dish Unboxing and Installation
  • ePMP 4600 6 GHz Fixed Wireless Broadband Access Point with Sector Antenna Unboxing
  • ePMP 4600 6 GHz Fixed Wireless Introduction
  • Enhance Customer Satisfaction with Fixed Wireless Solutions
  • Enhance Communities with Municipal Connectivity
  • WISPAPALOOZA Open House and Highlights
  • ePMP AX (5 GHz and 6 GHz) Technical Update
  • Virtual ANZ & PI WISP Forum
  • Competing with LEO Satellite Providers
  • High-Capacity Enterprise Access & Low-Cost Backhaul: Introducing the ePMP Force 400 Series
  • HeroTel ePMP 3000
  • ePMP Force 130
  • ePMP 3000L
  • ePMP 3000 Unboxing and Installation
  • What Makes a Good Sector Antenna
  • Security and Wireless Broadband
  • Cambium Innovation and Connectivity
  • CBN Indonesia
  • ePMP Urban and Rural Applications
  • What is Interference
  • ePMP How to View the Bridge Table
  • ePMP How to View Station Click Through
  • ePMP How to View and Change MIR Configuration
  • ePMP How to Upgrade Firmware on a GPS Sync Radio
  • ePMP How to Upgrade ePMP Device Software
  • ePMP How to Back Up and Restore ePMP Devices
  • ePMP How to Use ePMP eDetect
  • ePMP How to Configure an ePMP Access Point for GPS Sync
  • ePMP How to Configure an Access Point Using Quick Start
Events
Upcoming Events
View All Events
Sep162026
Tradeshow
Expo SmartISP
All Day Quito, Ecuador
Oct52026
Tradeshow
PITA Industry Week 2026
All Day Nadi, Fiji
Oct82026
Tradeshow
ENTELEC Fall Seminar
All Day Odessa, TX
Education & Training
Learning Opportunities
Connect & Learn
Join the Cambium Community
Visit Community Forum
50K+ Community Members
136K+ Forum Posts
