ePMP Force 300 CSM FSR Subscriber Module
Offers high performance and low latency across both point-to-multipoint and point-topoint deployments with a wide range of antenna options.
ePMP Force 300 CSM Connectorized Subscriber Module
Key Advantages
Asset 1
Up to 600 Mbps capacity and latencies as low as 2 ms when using PTP technology
Multi-User MIMO
Proven air interface on top of 802.11ac Wave 2 technology
Beamforming
Interoperability with the ePMP 3000, which uses MU-MIMO to achieve 1.2 Gbps per sector by transmitting to 2 Force 300 SMs simultaneously
5G-NR Signal
Integrated always-on spectrum analyzer for assessing the noise floor across a wide swath of 5 GHz spectrum
manageable
Multiple levels of Quality of Service (QoS) for voice, video, and data applications supporting a wide variety of service packages for both residential and enterprise users
uiArtboard 1
Security features meeting the requirements of enterprise, industrial, government, and service provider users
Specifications
MAC (Media Access Control) Layer
Cambium Proprietary
Physical Layer
Air interface on top of 802.11ac Wave 2 technology (2x2 MIMO/OFDM)
Ethernet Interfaced
100/100/1000BaseT, compatible with Cambium PoE & standard PoE pinouts
Protocols Used
IPv4/IPV6 (dual stack), UDP, TCP, ICMP, SNMPv2c, NTP STP, IGMP, SSH
Network Management
IPv4/IPv6, HTTPs, SNMPv2c, SSH, cnMaestro
VLAN
802.1Q with 802.1p priority
ARQ
Yes
Nominal Receive Sensitivity (w/FEC) @20 MHz Channel
MCS0 = -89 dBm to MCS8 (256 QAM-3/4) = -66 dBm (per chain)
Nominal Receive Sensitivity (w/FEC) @40 MHz Channel
MCS0 = -87 dBm to MCS9 (256QAM-5/6) = -64 dBm (per chain)
Nominal Receive Sensitivity (w/FEC) @80 MHz Channel
MCS0 = -84 dBm to MCS9 (256QAM-5/6) = -59 dBm (per chain)
Modulation Levels (Adaptive)
MCS0 (BPSK) to MCS 9 (256QAM 5/6)
Transmit Power Range
0 to +29 dBm (combined, to regional EIRP limit) (1 dB interval)
Surge Suppression
1 Joule Integrated
Environmental
IP67 & IP68
Temperature
-30°C to +60°C (-22°F to +140°F)
Weight
0.5 kg (1.1 lb) includes mounting bracket
Wind Survival
180 km/hour (112 mi/hour)
