Wireless Point-to-Point (PTP) Backhaul Solutions
Secure, Mission-Critical Wireless Backhaul for Commercial and Defense Networks
Cambium Networks’ proven wireless Point-to-Point (PTP) backhaul solutions are deployed worldwide to support mission-critical connectivity in the most demanding environments. From service provider and enterprise networks to government, public safety, and military communications, our PTP portfolio delivers high-capacity, low-latency performance with carrier-grade reliability. With FIPS 140-2 compliant security options and hardened designs built for extreme conditions, Cambium backhaul solutions provide secure, resilient links when performance and trust cannot be compromised.
cnWave 60 GHz
cnWave 60 GHz V1000 Client Node
The V1000 Client Node is featured with wide-range, 80º beamforming for easy installation. Powered by 802.3af PoE, V1000 supports up to 2 Gbps with 1 Gbps in the uplink direction and 1 Gbps in the downlink direction.
60 GHz Details
cnWave 60 GHz V2000 Client Node
The cnWave 60 GHz V2000 client node features a 2.5 GbE PoE input port as well as a 2.5 GbE PoE 802.3at output port for powering Wi-Fi access points or video surveillance cameras. This makes the V2000 especially well-suited to backhaul Cambium’s XV2 series of outdoor Wi-Fi AP’s.
60 GHz Details
cnWave 60 GHz V3000
Extend the Network with Wireless Cambium Networks’ 60 GHz cnWave solution provides easy, fast and cost-effective wireless gigabit connectivity for edge access and/or high-capacity Wi-Fi backhaul for edge access solutions at a significantly lower TCO than fiber infrastructure. Service providers and enterprises now have access to gigabit for business and residential connectivity, backhaul for Wi-Fi…
60 GHz Details
Sub 6 High Capacity Backhaul
PTP 550
Multicore Gigabit Radio – Performance in the presence of Interference
Sub 6 GHz Details
PTP 670
Field proven high reliable backhaul for small cell and critical infrastructure
4.9 GHz Details
PTP 700
One radio, multiple missions
Sub 6 GHz Details
PTP 45700 Beam Steering ODU
The PTP 45700 Beam Steering ODU with integrated Smart Antenna provides electronic beamforming that allows for easy tactical installation and best-in-class interference mitigation in addition to the industry-leading spectral efficiency and processing capabilities of the PTP 700 family of products.
Sub 6 GHz Details
Licensed Microwave Backhaul
PTP 820A
Split mount, multi-carrier, up to 1 Gbps
6 - 38 GHz Details
PTP 820C HP
All outdoor, dual core, High power 35 dBm, up to 1.2 Gbps
11-18 GHz Details
PTP 820E
All outdoor, 71-86 GHz, up to 2.5 Gbps
71-86 GHz Details
PTP 820S
All outdoor, single core, up to 600Mbps
11-18 GHz Details
PTP 850C
PTP 850C is next generation all-outdoor, multi-core unit. The PTP 850C has dual-core functionality enabling the system to operate up to 4 Gbps and deliver gigabit-plus capacity.
6 - 42 GHz Details
PTP 850CX
Capable of 4096 QAM with ACM, Supports 6-42 GHz (some bands are scheduled for future release).
6 - 42 GHz Details
PTP 850E
All outdoor, 71-86 GHz, up to 10 Gbps
71-86 GHz Details
PTP 850EX
Capable of 1024 QAM with ACM, Supports 71-76 GHz, 81-86 GHz
71-86 GHz Details
PTP 850EX-P
71-86 GHz Details
PTP 850GP
PTP 850GP is a highly-flexible, compact, high-performance indoor unit that delivers multi-Gbps radio capacity.
6 - 38 GHz Details
PMP 450 Backhaul family
PTP 450b
Backhaul links are the vital infrastructure that connects the network. You need confidence that your solution will work under heavy demand, regardless of the conditions. Licensed and unlicensed point-to-point (PTP) solutions from Cambium Networks perform reliably so that you can focus on your business. The PTP 450b features up to 300 Mbps in a 40 MHz channel. Frequency range is 4.9 – 5.925 GHz.
4.9 GHz Details
5 GHz PMP 450b High Gain Subscriber Module
High-gain fixed wireless subscriber module delivers up to 300 Mbps throughput in a 40 MHz channel with 4.9 to 5.925 GHz operation.
4.9 GHz Details
PTP 450i Fixed Wireless Backhaul
Fit to comprehensive network with dynamic interference filtering
4.9 GHz Details
PTP 450v 2×2
Both the 2x2 PTP 450v and 4x4 PTP 450v support up to 2x40 MHz of operating spectrum to deliver over 500 Mbps of data.
5 GHz Details
PTP 450v 4×4
5 GHz Details
ePMP Backhaul Family
ePMP Force 300-19R
Combining the latest 802.llac Wave 2 technology and the field proven scalable performance of ePMP, the Force 300-19R delivers up to 600 Mbps of capacity. The Force 300-19R is a powerful yet affordable subscriber module compatible with the ePMP3000 Access Point and using the forward compatibility features also interoperates with the ePMP 2000 to ease the migration into the 802.llac Wave 2 technology. The Force 300-19R has a 19 dbi integrated antenna with a narrow beamwidth and reliable IP67 mechanics.
4.9 GHz Details
ePMP Force 300-25
Cambium Networks’ ePMP Force 300-25 is designed to operate in high interference environments and provides superior throughput of over 500 Mbps of real user data.
Sub 6 GHz Details
Tower Switches
cnMatrix TX2012R-P Switch
104 Gbps throughput, 8 PoE+ enabled ports, 8 10/100/1000 Mbps ports, 4 SFP+ Uplink ports
cnMatrix TX2020R-P Switch
112 Gbps throughput, 16 PoE+ enabled parts, 16 10/100/1000 Mbps ports, 4 SFP+ Uplink ports
Feature Comparison
ATTRIBUTES
cnWave
v3000
ePMP
Force 425
ePMP
F300
450b
PTP
550
PTP
670
Max Throughput (up to) 3.6 Gbps 1.0 Gbps 600 Mbps 300 Mbps 1.44 Gbps 450 Mbps
Spectrum Efficiency (bits/HZ/s) 1.67 12.5 7.5 7.5 9 10
Frequency Range (GHz) 57 to 66 4.910 to 6.135 4.9 to 5.9 4.9 to 5.9 5.1 – 5.9 4.9 to 6
Channel BW MHz 2.16 GHz 20/40/80 20/40/80 5/10/15/20/30/40 2x 20/40/80 5/10/15/20/30/40/45
Channel bonding Roadmap No No No Yes No
Top Modulation 16 QAM 1024 QAM 256 QAM 256 QAM 256 QAM 256 QAM
Packets Processed per Second 80,000 80,000 50,000 120,000 850,000
Integrated Antenna 40.5 or 44.5 dBi 25 dBi 13/16/19/25 dBi 17/24 dBi 23 dBi 23 dBi
Latency < 1 ms 3-6 ms 3-6 ms 3-5 ms 3-6 ms 1-3 ms
Tx Power 19 dBm beam-forming 28 dBm 27 dBm 27 dBm 26 dBm 27 dBm
Jumbo Frame 4000 bytes 1700 bytes 1700 Bytes 1700 Bytes 1700 Bytes 9600 Bytes
Online Spectrum Analyzer No Yes Yes Standby Yes Yes
DSO No No No No No Yes
Encryption 128 AES 128 AES 128 AES 128 AES 128 AES 128 & 256 AES
1588 Timing & SyncE 1588 (Roadmap) No No No No Yes
QOS 4 level 3 level 3 Level 4 Level 3 Level 8 Levels
PoE output Yes No No No No Yes
SFP Fiber Port Yes Yes No No Yes Yes
TDD Sync Yes No Yes Yes Yes Yes
TDM T1/E1 No No No No No Yes
IP Rating IP67 IP67 IP55 (F300-19R=IP67) IP67 IP67 IP67
Power Consumption 30 W 28 W 12 W 12 W < 30 W <30 W
Events
Upcoming Events
View All Events
Aug252026
Tradeshow
Broadband Communities Summit
All Day Houston, TX
Aug252026
Industry Event
MDU Rendezvous
7:00 pm The Grotto in the George R. Brown Convention Center
Aug262026
Webinar
MDU Rendezvous Part 2: Here We Go Again
Todd Thorpe, Director of Business Development with Cambium Networks and Scott Casey, CEO and Founder of ROVR Wi-Fi Score and…
12:00 pm Online
Education & Training
Learning Opportunities
Connect & Learn
Join the Cambium Community
Visit Community Forum
50K+ Community Members
136K+ Forum Posts
