Cambium Networks’ ePMP™ product line has set the standard for high performance, scalability and reliability in harsh interference environments all at a compelling price. The ePMP 3000 is the third generation access point (AP) that carries on the interference tolerance mechanisms from ePMP 2000 but adds the power of Multi-User MIMO (MU-MIMO). The ePMP 3000 is a 4×4 MU-MIMO access point that can double the throughput at the sector level with the same channel bandwidth by serving two subscribers at the same time.
ePMP 3000
Specifications
SPECTRUM
Channel Spacing
            Configurable on 5 MHz increments
       Frequency Range
            4910–5980 MHz (exact frequencies as allowed by local regulations)
       Channel Width
            10 | 20 | 40 | 80 MHz  (NOTE: 10 MHz bandwidth is supported only with Force 300-19R SM. Also note that 11n SM's can connect and operate in 10MHz)
       INTERFACE
MAC (Media Access Control) Layer
            Cambium Proprietary
       Physical Layer
            4x4 MUMIMO/OFDM
       Ethernet Interfaced
            100/1000BaseT, rate auto negotiated, 802.3at compliant & Aux SFP port
       Powering Methods Supported
            56 V PoE (included), standard 802.3at PoE Supply, or CMM5 with 56 V and 5 pin to 7 pin cross over cable adapter
       Protocols Used
            IPv4/IPV6 , UDP, TCP, IP, ICMP, SNMPv2c, HTTPs, STP, SSH, IGMP Snooping
       Network Management
            HTTPs, SNMPv2c, SSH
       VLAN
            802.1Q with 802.1p priority
       PERFORMANCE
Subscribers per Sector
            Up to 120
       ARQ
            Yes
       Nominal Receive Sensitivity (w/FEC) @20 MHz Channel
            MCS 0 , -92  MCS 8 supported by Wi-Fi -68
       Nominal Receive Sensitivity (w/FEC) @40 MHz Channel
             MCS0, -89  MCS9, -64
       Nominal Receive Sensitivity (w/FEC) @80 MHz Channel
            MCS0, -86, MCS9 - 61
       Modulation Levels (Adaptive)
            MCS0 (BPSK) to MCS 9 (256 QAM 5/6)
       GPS Synchronization
            Yes, via Internal GPS or Cambium Sync (Internal GPS receiver also contains a patch antenna and can be used without  the external puck antenna)
       Quality of Service
            Three level priority (Voice, High, Low) with packet classification by DSCP, COS, VLAN ID, IP & MAC Address, Broadcast,  Multicast and Station Priority, MIR/CIR support*
       DSO*
            Dynamic Spectrum Optimization. Ability to change channels based on interference detection on current channel
       Fast DFS*
            Change to alternate radar free channel with background availability check
