NSE 4000
Next-Gen Firewall and Unified Threat Management
Network Service Edge (NSE) delivers a next-gen firewall and unified threat management (UTM) for organizations requiring a complete security and SD-WAN solution. NSE enables Cambium’s ONE Network, unifying Wi-Fi, switching, security, SD-WAN, wireless backhaul, and fiber in a single, cloud-managed network.
Cambium Networks’ NSE 4000 delivers best-in-class advanced security, SD-WAN, and network services for small and medium enterprise networks. Additionally, NSE 4000 features 8 multi-gig (2.5G) Ethernet ports and dual 10G SFP+ uplinks with 10 Gbps firewall / 3.2 Gbps encrypted IPS throughput.
SD-WAN
Resilient application-intelligent WAN edge
  • Routing
  • WAN failover
  • QoS
  • Traffic shaping
  • Starlink monitoring
SECURITY
Network protection for ongoing/emerging threats
  • NG Firewall
  • IDS / IPS
  • Application control
  • Content filtering
  • Site-to-site VPN
  • IoT security
SERVICES
Core services in one integrated solution
  • DHCP
  • DNS
  • RADIUS
  • Vulnerability Assessment
LAN Vulnerability Assessment
NSE 4000 provides 24×7 vulnerability assessment for all wireless and wired devices connected to the local network. The service runs periodic scans to detect CVE (Common Vulnerabilities and Exposures) and provides a score with recommended remediation.
NSE IoT Security
IoT Security
NSE 4000 addresses the cyber security risks and scale challenge of supporting OT/IoT devices on the network. These devices often cannot be readily updated to address security issues and need to be proactively monitored. Via AI-based methods, NSE automatically identifies and protects IoT devices from external threats.
NSE Application Control
Application Control
Application Control on NSE provides visibility and control of more than 5,000 apps. Block, rate-limit, or prioritize applications based on desired business outcomes. Segment ISP traffic across multiple WAN links based on different latency and performance requirements.
NSE Starlink Integration
Starlink Satellite Integration
NSE 4000 integrates with Starlink® satellite internet systems to improve manageability, security, and enterprise scalability on networks using these systems. Monitor throughput, latency, drops, dish alignment, and more in real-time across multiple sites.
Public IP with WireGuard VPN
NSE 4000 enables public IP addressing over CGNAT. Assign real, static public IPv4 addresses to remote locations behind Starlink, LTE or any CGNAT network using WireGuard® VPNs to ensure consistent and always-reachable IP access.
NSE ONE Network Solution
Cambium’s ONE Network Solution
NSE 4000 provides the security and SD-WAN edge for an end-to-end Cambium network that delivers holistic security and visibility for the wireless and wired LAN. Together with cnMaestro, you can build a complete and easy-to-deploy network managed from one console.
Security vs Security Plus
Feature Security No subscription Security Plus Recommended
SD-WAN
WAN Load Balancing (Active-Active & Active-Backup)
Flow Preferences (L3 & L7)
Traffic Shaping
Failover Policies
VPN
Site-to-Site VPN (IKEv1, IKEv2 — Hub & Spoke, Mesh)
Remote VPN (L2TP-IPSec, IKEv2, WireGuard)
Virtual WAN — Public IP over CGNAT (WireGuard)
Auto VPN (One-Click Tunnel Setup)
IoT Device Identification
Firewall
Next-Gen Firewall — Layer 3 (IP-based)
Next-Gen Firewall — Layer 7 (Application-based)
Geo-IP Firewall (LAN→WAN & WAN→LAN)
Threat Protection
Intrusion Detection & Prevention (IDS/IPS)
Content Filtering
DNS Content Filtering (80+ categories, Safe Search)
Analytics & Visibility
Application Visibility & Control
RADIUS Authentication
cnMaestro Reports & Analytics
Cloud Management
cnMaestro Essentials
cnMaestro X
High Availability
1+1 Active-Backup HA
No other firewall gives you this much at zero cost. SD-WAN, NGFW, IDS/IPS, site-to-site & remote VPN, application control, and cloud management — all included with the hardware. No subscriptions, no feature gates, no per-device fees. Security Plus adds advanced capabilities when you’re ready, but the free tier alone outperforms competitors’ paid offerings.
How NSE Solves Real-World Problems
NSE Guided demos
Discover how NSE streamlines network operations, enhances security, and facilitates remote connectivity, providing a seamless and secure networking experience.
NSE 4000
Specifications
Recommended
Sites, branches, and headquarters with up to 2,500 devices
Routed Throughput (Layer-3 Forwarding Throughput)
10 Gbps*
Advanced Security Throughput (NAT+AVC+IPS+ACL)
3.3 Gbps*
*Throughput values are “up to” and may vary depending on system configuration.
Site-to-Site VPN
200 site-to-site VPN tunnels
WAN Ports
1 x 10 GbE SFP+, 1 x 2.5 GbE RJ45 (reconfigurable up to 5 WAN ports)
LAN Ports
1 x 10 GbE SFP+, 7 x 2.5 GbE RJ45 (reconfigurable)
PoE+ Ports
P7/P8/P9/P10 RJ45 ports
Dimensions
330 mm x 230 mm x 44 mm
Weight
3.24 kg
Operating Temperature
0ºC–40ºC
Power Supply
100-240 V AC, 50-60 Hz
Resources
Documentation
  • All-in-One Security: Exploring the NSE 4000 Firewall
