ePMP 3000
Cambium Networks’ ePMP™ product line has set the standard for high performance, scalability and reliability in harsh interference environments all at a compelling price. The ePMP 3000 is the third generation access point (AP) that carries on the interference tolerance mechanisms from ePMP 2000 but adds the power of Multi-User MIMO (MU-MIMO). The ePMP 3000 is a 4×4 MU-MIMO access point that can double the throughput at the sector level with the same channel bandwidth by serving two subscribers at the same time.
Where to Buy
Key Features
media-radioArtboard 1
Frequency Reuse
Supports GPS synchronization and SM Transmit power control to allow for frequency re-use.
bar-chartArtboard 1
Unmatched Performance and Scalability
With the efficient Cambium Networks MAC protocol and advanced air-fairness scheduler up to 120 simultaneously active subscriber modules can be served without performance degradation.
designArtboard 1
Industry-Leading Interference Tolerance
The intelligent filtering capability on the receive side makes ePMP 3000 immune to the effects of strong off-channel interferers and on the transmit side serves to reduce off-channel noise for better radio co-location.
Multi-User MIMO
Industry-Leading Spectral Efficiency
MU-MIMO in the downlink doubles the sector capacity by serving two MIMO users at the same time.
ePMP 3000
Specifications
Channel Spacing
Configurable on 5 MHz increments
Frequency Range
4910–5980 MHz (exact frequencies as allowed by local regulations)
Channel Width
10 | 20 | 40 | 80 MHz (NOTE: 10 MHz bandwidth is supported only with Force 300-19R SM. Also note that 11n SM's can connect and operate in 10MHz)
MAC (Media Access Control) Layer
Cambium Proprietary
Physical Layer
4x4 MUMIMO/OFDM
Ethernet Interfaced
100/1000BaseT, rate auto negotiated, 802.3at compliant & Aux SFP port
Powering Methods Supported
56 V PoE (included), standard 802.3at PoE Supply, or CMM5 with 56 V and 5 pin to 7 pin cross over cable adapter
Protocols Used
IPv4/IPV6 , UDP, TCP, IP, ICMP, SNMPv2c, HTTPs, STP, SSH, IGMP Snooping
Network Management
HTTPs, SNMPv2c, SSH
VLAN
802.1Q with 802.1p priority
Subscribers per Sector
Up to 120
ARQ
Yes
Nominal Receive Sensitivity (w/FEC) @20 MHz Channel
MCS 0 , -92 MCS 8 supported by Wi-Fi -68
Nominal Receive Sensitivity (w/FEC) @40 MHz Channel
MCS0, -89 MCS9, -64
Nominal Receive Sensitivity (w/FEC) @80 MHz Channel
MCS0, -86, MCS9 - 61
Modulation Levels (Adaptive)
MCS0 (BPSK) to MCS 9 (256 QAM 5/6)
GPS Synchronization
Yes, via Internal GPS or Cambium Sync (Internal GPS receiver also contains a patch antenna and can be used without the external puck antenna)
Quality of Service
Three level priority (Voice, High, Low) with packet classification by DSCP, COS, VLAN ID, IP & MAC Address, Broadcast, Multicast and Station Priority, MIR/CIR support*
DSO*
Dynamic Spectrum Optimization. Ability to change channels based on interference detection on current channel
Fast DFS*
Change to alternate radar free channel with background availability check
