PMP 450i Fixed Wireless Access Point
Specifications
SPECTRUM
Channel Spacing
Configurable on 2.5 MHz increments, 3 GHz customizable to 50 KHz
Frequency Range
3 GHz : 3300 - 3900 MHz, 5 GHz : 4900 - 5925 MHz
Channel Width
5 MHz, 7 MHz, 10 MHz, 15 MHz, 20 MHz, 30 MHz or 40 MHz
INTERFACE
MAC (Media Access Control) Layer
Cambium Networks proprietary
Physical Layer
2x2 MIMO OFDM
Ethernet Interface
100/1000BaseT, full duplex, rate auto negotiated (802.3 compliant)
Protocols Used
IPv4, IPv6, UDP, TCP/IP, ICMP, Telnet, SNMP, HTTP, FTP
Network Management
IPv4/IPv6 (dual stack), HTTP, HTTPS, Telnet, FTP, SNMPv2c and v3, Cambium Networks cnMaestroTM
MTU
1700 bytes
VLAN
802.1ad (DVLAN Q-inQ), 802.1Q with 802.1p priority, dynamic port VID
PERFORMANCE
Subscriber Per Sector
Up to 238
ARQ
Yes
Maximum Deployment Range
Up to 40 miles (64 km)
Latency
3 - 5 ms, typical
GPS Synchroization
Yes, via Autosync (CMM5 or UGPS)
Quality of Service
Diffserve QoS
PHYSICAL
Antenna Connection
50 ohm, N-Type (Connectorized version only)
Surge Suppression (LPU fitted)
EN61000-4-5: 1.2us/50us, 500 V voltage waveform Recommended external surge suppressor: Cambium Networks Model # C000000L033A
Mean Time Between Failure
> 40 Years
Environmental
IP67, IP66
Temperature / Humidity
-40°C to +60°C (-40°F to +140°F), 0-100% condensing
