ePMP 3000 FSR 5.1–5.9 GH
Cambium Networks’ ePMP™ product line has set the standard for high performance, scalability and reliability in harsh interference environments, all at a compelling price. The ePMP 3000 FSR 5.1-5.9 GHz series is the third generation access point (AP) based on 802.11ac Wave 2 technology. These APs interoperate with Force 300 Subscriber Modules (SM) and support backward compatibility.
Where to Buy
Specifications
Channel Spacing
Configurable in 5 MHz increments
Frequency Range
Wide-band operation; 5100–5970 MHz*
Channel Width
20 | 40 | 80 MHz
*Allowable frequencies and bands are dictated by individual country regulations.
MAC (Media Access Control) Layer
Cambium proprietary
Physical Layer
4x4 MUMIMO/OFDM
Ethernet Interfaced
100/1000 BaseT, rate auto-negotiated, 802.3at compliant, Aux SFP port
Powering Methods Supported
56 V PoE (included), standard 802.3at PoE Supply, or CMM5 with 56 V and 5 pin to 7 pin crossover cable adapter
Protocols Used
IPv4/IPV6 , UDP, TCP, IP, ICMP, SNMPv2c, HTTPs, STP, SSH, IGMP snooping
Network Management
HTTPS, SNMPv2c, SSH
VLAN
802.1Q with 802.1p priority
Subscribers per Sector
Up to 120
ARQ
Yes
Modulation Levels (Adaptive)
MCS 0 (BPSK) to MCS 9 (256 QAM-5/6)
GPS Synchronization
Yes, via internal GPS or Cambium Sync
Quality of Service
Three-level priority (voice, high, low) with packet classification by DSCP, COS, VLAN ID, IP & MAC Address; Broadcast, multicast, and station priority; DS0; DSF
