PTP 850CX is a next-generation ultra-high capacity microwave radio designed to meet the increasing demands for reliable, scalable wireless backhaul. As a compact all-outdoor solution, the PTP 850CX delivers multi-gigabit throughput with low latency and high spectral efficiency, enabling wireless ISPs, municipality, public safety, and enterprises to build resilient networks with simplified architecture.
PTP 850CX
Specifications
RADIO
Radio Specs
6-42 GHz
1+0 up to 4+0 single/dual polarization, 1+1/2+2 HSB, 2+0 XPIC, 2x2+0 east/west single/dual polarization*
4+0 layer aggregation
Enhanced multi-carrier ABC (up to 2+0)
Channel bandwidth: 14 to 224 MHz
ETHERNET
Ethernet Interfaces
Port 1: DC port
Port 2: RJ45 - Electric 100 Mbps/1 Gbps traffic/PoE
Port 3: SFP+ - 1/2.5/10 traffic
Port 4: SFP28 - 1/10/25G traffic
Port 5: RJ-45 - Management/protection/100 Base-T
Ethernet Features
MTU – 9,612 Bytes
Up to 1024 Ethernet services plus one pre-defined management service
VLAN add/remove
Y.1731 Ethernet OAM; Y1.731 Ethernet bandwidth notification
TECHNICAL SPECIFICATIONS
Mechanical
270 mm x 230 mm x 98 mm
5.3 kg
Environmental
-33°C to +55° ( -27°F to +131°F)
Power Input Specifications
Standard Input: -48 VDC, PoE
DC Input range: -40.5 to -60 VDC
