Bridge-in-a-Box 1 GB
What Is Bridge-in-a-Box 1Gb?
Each Bridge-in-a-Box comes with everything you need to extend your network from wherever you have an Ethernet port to wherever you need one. The Gigabit modules use the unlicensed 60 GHz frequency band and are pre-configured and pre-paired to connect.
For those places you couldn’t connect before, Bridge-in-a-Box is all you need:
  • Extend Internet connectivity
  • Connect remote or outdoor Wi-Fi hotspots
  • Connect remote camera or CCTV video feeds
Unboxing the 1 GB Bridge in a Box
cnWave 60 GHz V1000 Client Node
Have questions, need install advice or would like to help?
Visit the Cambium Community!
Join the Community
60 GHz Bridge-in-a-Box 1 GB
Specifications
Wireless Standard
802.11ay
Frequency Range
57 to 66 GHz in a single SKU
Channel Bandwidth
2.16 GHz, 4.32 GHz with channel bonding for up to 2 adjacent channels
Ethernet Interface
1 x 100/1000 BaseT with PoE In
Modulation Levels
MCS-0 (BPSK) to MCS-10 (16-QAM)
Weight
0.25 kg (0.55 lbs)
Dimensions (h x w x d)
169 mm x 100 mm x 54 mm (6.65 in x 3.94 in x 2.13 in)
Wind Survival
200 km/h (124 mi/h)
Resources
Documentation
  • Brine Leas Academy Improves Education with Better Wi-Fi across the Campus
  • cnWave 60 GHz V1000 Fixed Wireless Client Node
