PTP 850EX-P
Specifications
RADIO
Radio Specs
71-76 GHz, 81-86 GHz
1+0, 2+0, 1+1 HSB
Multiband with PTP 820 and PTP 850 families*
Radio Features
BPSK to 1024 QAM with hitless ACMB
ATPC
Adaptive bandwidth notification (EOAM)
ETHERNET
Ethernet Interfaces
Port 1: DC port
Port 2: RJ45, 1 GbE (management/traffic/PoE)
Port 3: SFP28 - 1/2.5/10/25 GbE
Port 4: SFP28 - 1/2.5/10/25 GbE
Port 5: QSFP
Ethernet Features
MTU – 9612 Bytes
4K
VLAN add/remove/translate
TECHNICAL SPECIFICATIONS
Mechanical Specs
Dimensions (Direct Mount): 228 mm x 233 mm x 76 mm
Weight 2.77 kg
Environmental Spec
-40°C to +55°C (-40°F to +131°F)
Power Input Specifications
Standard Input: -48 VDC, PoE
DC Input range: -40.5 to -60 VDC
