the 2×2 PTP 450v support up to 2×40 MHz of operating spectrum to deliver over 500 Mbps of data.
PTP 450v 2×2
Specifications
SPECTRUM
Channel Spacing
Configurable on 2.5 MHz increments
Frequency Range
5.1.50 GHz - 7.125 GHz
INTERFACE
MAC (Media Access Control) Layer
Cambium Networks proprietary
Physical Layer
2x2 MIMO OFDM
Ethernet Interface
100/1000BaseT, full duplex, rate auto negotiated (802.3 compliant)
Protocols Used
IPv4, IPv6, UDP, TCP/IP, ICMP, Telnet, SNMP, HTTP, FTP
Network Management
IPv4/IPv6 (dual stack), HTTP, HTTPS, Telnet, FTP, SNMPv2c and v3, cnMaestro
MTU
1700 bytes
VLAN
802.1ad (DVLAN Q-inQ), 802.1Q with 802.1p priority, dynamic port VID
SECURITY
Encryption
FIPS-197 128-bit AES, 256-bit AES (optional)
PHYSICAL
Dimensions (diameter x depth)
469 mm x 364 mm
Weight
1.2 kg (radio); 4.0 kg (with dish & bracket)
Temperature
-40°C to +60°C
Humidity
0%-95% condensing
Wind Survival
200 kph
