The cnPilot™ e501S 802.11ac Outdoor Sector Access Point includes an IP67 enclosure, 90° ~ 120° integrated sector antenna, supports 256 client associations, 16 SSIDs, WPA-2 encryption, Dynamic VLANs, DFS channels, Access Control Lists (ACL), and more.
cnPilot e501S Wi-Fi 5 Outdoor Wireless Access Point
Specifications
ACCESS POINT
FREQUENCY BANDS
2.4 GHz: 2.4 – 2.4835 GHz Channels 1 – 13 (ETSI/CE), Channels 1 – 11 (US) 5 GHz: 5.15 – 5.85 GHz
SSID SECURITY
WPA-2 (802.11i): WPA2-Enterprise (802.1x/EAP) & WPA2-Preshared-keys, Open
MAX SSIDS
16
MAX CONCURRENT CLIENTS
256
MAX RANGE
Client: 213 m (700 Ft); Actual range will vary based on local RF conditions & client capability. Mesh: 2.4 GHz: 3,000 m (9840 Ft.) 5 GHz: 1,500 m (4,900 Ft.)
MAX DATA RATES
1.16 Gbps
PHYSICAL
DIMENSIONS (CM)
30 x 20.4 x 6.5 cm (without bracket)
WEIGHT
Without bracket: 881 g (0.88 Kg); with Bracket: 1,063 g (1.06 Kg)
MOUNTING OPTIONS
Pole mount bracket (included) or wall-mount (with included bracket or without)
PHYSICAL SECURITY
Kensington Lock bracket
WIFI FEATURES
Controller modes
• Autonomous Controller-less operations (E.g.: roaming) • Cloud Managed • On-premise virtualized controller
Secure WLAN
• WPA-TKIP, WPA2 AES, 802.1x • 802.11w (Protected Management Frames)
Hotspot 2.0/Passpoint
Yes
Captive Portal
• cnMaestro Controller • Stand-alone AP based • Redirection to external RADIUS • Server DNS logging
Authentication
• RADIUS based 802.1x including EAP-SIM/AKA, EAP-PEAP, EAP-TTLS, and EAP-TLS • MAC authentication (local database or External RADIUS server)
Scheduled SSID
Turn SSID ON/OFF on a daily/weekly/time of day basis
