ePMP Force 400 Series
Cambium Networks ePMP™ Force 400 series point-to-point solutions deliver up to 1 Gbps throughput, at a breakthrough price point, based on the latest 802.11ax standards.
Where to Buy
ePMP Force 400C and Force 425
Cambium Networks’ ePMP Force 425 and Force 400C point-to-point solutions deliver up to 1 Gbps throughput at a breakthrough price point, based on the latest 802.11ax standards.
The Force 400 Series is the ideal solution for service providers looking to deliver high-capacity access services to enterprise and residential customers.
It also serves as a low-cost backhaul for MicroPOPs and outdoor Wi-Fi access points that require a lot of capacity at moderate range without the overhead of licensed microwave.
With an integrated SFP port and optional GPON ONU module, the Force 425 makes a great fiber extension to reach places where fiber cannot.
The Force 425 pushes this capacity farther than ever with an integrated 25 dBi dish (and even farther with the optional 28 dBi range extender, available separately). The optional range extender can be assembled and attached in the field to add additional link budget and fade margin for challenging links or to move to higher capacity, where needed, and higher modulations can be achieved.
For even longer range applications, the Force 400C is a connectorized option with two RP-SMA RF interfaces for use with larger parabolic dishes or horn antennas.
Leveraging the latest technology from the 802.11ax standard and Cambium’s proprietary ePTP mode, the Force 400 series delivers high spectral efficiency with features such as:
1024QAM
80 MHz channels
Highly efficient frame structure
Proven ePTP air interface
The Force 400 Series delivers Gbps performance with less than 5 ms latency.
The Force 400 series has enterprise-grade security with 128-bit AES over-the-air encryption (256-bit AES where export rules allow), secure management interfaces with roles-based authentication, and standards-based device authentication including RADIUS support. It’s built for real-world applications with IP67 ruggedization, simplified mounting scheme, and Cambium’s 3-year hardware warranty.
Plan and manage your Force 425/400C deployments with Cambium’s LINKPlanner and cnMaestro Network Management.
Specifications
Channel Width MHz
20 | 40 | 80
Proprietary Physical Layer
802.11ax, 2x2 MIMO/OFDM
Channel Spacing
Configurable in 5 MHz increments
ROW Frequency Range
Wide Band Operation 4920–6180 MHz
FCC/IC Frequency Range
Wide Band Operation 4920–5885 MHz
NOTE:
Country-dependent based on local regulations
ARQ
Yes
Maximum Capacity
1 Gbps
Latency
< 5 ms
Transmit Power Range
+3 to +28 dBm (combined, to regional EIRP limit) (1 dB interval)
Force 400C Connectors
1 x RJ-45, 1 x SFP, 2 x RP-SMA
Force 425 Connectors
1 x RJ-45, 1 x SFP
Surge Supression*
1 Joule Integrated
Environmental
IP67
Power Consumption
28 W
Input Voltage
802.3at or Passive PoE 44-59 V
