What Is Bridge-in-a-Box UHD PRO?
Each Bridge-in-a-Box comes with everything you need to extend your network from wherever you have an Ethernet port to wherever you need one, from 50 feet to 5 miles away (20 meters to 8 kilometers). The modules use the unlicensed 5 GHz frequency band and are pre-configured and pre-paired to connect.
For those places you couldn’t connect before, Bridge-in-a-Box is all you need:
  • Extend internet connectivity
  • Connect remote Wi-Fi hotspots
  • Connect remote camera or CCTV video feeds
What Do People Connect with Bridge-in-a-Box?
  • Machine shops, garages, storage sheds
  • Docks, boat ramps
  • Any remote or outlying buildings
  • Remote parking lots
  • Campus buildings
  • Cabins, lodges
  • Construction sites
  • Temporary events (concerts, farmers markets, sports)
Bridge-in-a-Box UHD PRO Specifications Overview
  • Includes 2 wireless radio modules and power-over-Ethernet (PoE) supplies
  • Uses 5 GHz unlicensed frequency band
  • Up to 600 Mbps total throughput
  • Range up to 8 kilometers (5 miles)
  • 3-year warranty
Have questions, need install advice or would like to help?
Visit the Cambium Community!
Specifications
Features
Wireless Standard
ePTP proprietary protocol. Supports longer ranges, lower latency, and greater performance. Optional Standard Wi-Fi mode of operation available.
Wired Interface
Gigabit / Fast Ethernet
Functions
Traffic prioritization using ePMP QoS (Quality of Service), WEP security.
Spectrum
Frequency Range
4910 – 5970 MHz
Channel Spacing
Configurable on 5 MHz increments
Frequency Range
5 GHz: 4910 – 5970 MHz (exact frequencies as allowed by local regulations)
Channel Width
5 | 10 | 20 | 40 | 80 MHz
Performance
ARQ
Yes
Nominal Receive Sensitivity (w/FEC) @20MHz Channel
MCS0 = -93 dBm to MCS15 = -72 dBm (per branch)
Nominal Receive Sensitivity (w/FEC) @40MHz Channel
MCS0 = -90 dBm to MCS15 = -69 dBm (per branch)
Quality of Service
Three level priority (Voice, High, Low) with packet classification by DSCP, COS, VLAN ID, IP & MAC Address, Broadcast, Multicast and Station Priority
Physical
Weight
1.45 kg (3.2 lbs) (including mounting bracket)
Dimensions (h x w x d)
27.8 x 27.8 x 4.5 cm (10.9 x 10.9 x 1.8 in) without mounting bracket
Wind Survival
180 km/h (112 mph)
Documentation
