What Is 5 GHz Bridge-in-a-Box 1Gb?
Each Bridge-in-a-Box comes with two wireless radio modules and related accessories that can be used to easily connect point A to point B at Gigabit speed.
For those places you couldn’t connect before, Bridge-in-a-Box is all you need:
  • Extend internet connectivity
  • Connect remote Wi-Fi hotspots
  • Connect remote camera or CCTV video feeds
What Do People Connect with Bridge-in-a-Box?
  • Machine shops, garages, storage sheds
  • Docks, boat ramps
  • Any remote or outlying buildings
  • Remote parking lots
  • Campus buildings
  • Cabins, lodges
  • Construction sites
  • Temporary events (concerts, farmers markets, sports)
Bridge-in-a-Box 5 GHz Specifications Overview
  • Uses the 5 GHz frequency band
  • Up to 1 Gbps total throughput
  • Range up to 5 kilometers (3 miles)
  • Supports NLOS
  • 3-year warranty
Have questions, need install advice or would like to help?
Visit the Cambium Community!
Specifications
Features
Wireless Standard
ePTP proprietary protocol supporting lower latencies, longer ranges, and higher reliability
Spectrum
Frequency Range
5450–5920 MHz (exact frequencies as allowed by local regulations)
Channel Bandwidth
20 | 40 | 80 MHz
Performance
Ethernet Interface
10/100/1000 Base T, compatible with Cambium PoE & standard PoE pinouts
Modulation Levels
MCS-0 (BPSK) to MCS-11 (1024 QAM-5/6)
Physical
Weight
2.76 kg (6.1 lb) with mounting bracket
Dimensions (h x w x d)
180 mm x 210 mm x 39 mm (7 in x 8.2 in x 1.5 in) without mounting bracket
Wind Survival
180 km/h (112 mi/h)
Documentation
