Bridge-in-a-Box 2GB
What Is Bridge-in-a-Box 2Gb?
Each Bridge-in-a-Box comes with everything you need to extend your network from wherever you have an Ethernet port to wherever you need one. The Gigabit modules use the unlicensed 60 GHz frequency band and are pre-configured and pre-paired to connect.
For those places you couldn’t connect before, Bridge-in-a-Box is all you need:
  • Extend internet connectivity
  • Connect remote or outdoor Wi-Fi hotspots
  • Connect remote camera or CCTV video feeds
  • Machine shops, garages, storage sheds
  • Docks, boat ramps
  • Any remote or outlying buildings
  • Remote parking lots
  • Campus buildings
  • Cabins, lodges
  • Construction sites
  • Temporary events (concerts, farmers markets, sports)
  • Includes 2 wireless radio modules and power-over-Ethernet (PoE) supplies
  • Uses the 60 GHz unlicensed frequency band
  • Up to 3.6 Gbps total throughput
  • Range up to 500 meters (0.3 miles)
  • PoE output port for camera or Wi-Fi access point
  • 3-year warranty
Unboxing the 2 GB Bridge in a Box
Have questions, need install advice or would like to help? Visit the Cambium Community!
Join the Community
60 GHz Bridge-in-a-Box 2GB
Specifications
Wireless Standard
802.11ay
Frequency Range
57 to 66 GHz in a single SKU
Channel Bandwidth
2.16 GHz, 4.32 GHz with channel bonding for up to 2 adjacent channels
Ethernet Interface
1 x 100/1000 BaseT with PoE In
Modulation Levels
MCS-0 (BPSK) to MCS-10 (16-QAM)
Weight
0.25 kg (0.55 lbs)
Dimensions (h x w x d)
169 mm x 100 mm x 54 mm (6.65 in x 3.94 in x 2.13 in)
Wind Survival
200 km/h (124 mi/h)
Resources
Documentation
