Discontinued
ePMP Force 300 CSM Connectorized Subscriber Module
Cambium Networks’ ePMP™ Force CSM is designed to operate in high interference environments and provides superior throughput of over 500 Mbps of real user data. ePMP Force 300 CSM FSR is still available. Click here for more information.
Where to Buy
Key Advantages
  • Cambium Networks’ ePMP Force 300 CSM is designed to operate in high interference environments and provides superior throughput of over 500 Mbps of real user data.
  • The ePMP Force 300 CSM supports channel size configurations from 20 MHz up to 80 MHz and modulations up to 256 QAM.
  • Configurable modes of operation ensure robust adaptivity to both symmetrical and asymmetrical traffic while providing high performance and round-trip latency as low as 3-5 ms.
  • QoS management offers an outstanding quality for triple play services – VoIP, video, data – and provides three levels of traffic priority.
  • Long deployment range is enabled by up to 27dBm of transmit power and connectorized antenna ports.
  • The Force 300 CSM offers deployment versatility with options for parabolic dishes and compatibilty with the RF Elements TwistportTM ePMP adaptor.
  • Installation is a breeze with the easy to install mount, capable of pole and wall mounting.
Specifications
MAC (Media Access Control) Layer
Cambium Proprietary
Physical Layer
2x2 MIMO/OFDM
Ethernet Interfaced
10/100/1000 BaseT, Compatible with Cambium PoE & Standard PoE pinouts
Protocols Used
IPv4/IPv6 (Dual Stack), UDP, TCP, ICMP, SNMPv2c, NTP, STP, IGMP, SSH
Network Management
IPv4/IPv6, HTTPs, SNMPv2c, SSH, Cambium Networks cnMaestro™
VLAN
802.1Q with 802.1p priority
ARQ
Yes
Nominal Receive Sensitivity (w/FEC) @20 MHz Channel
MCS0 = -89 dBm to MCS8 (256 QAM-3/4) = -66 dBm (per chain)
Nominal Receive Sensitivity (w/FEC) @40 MHz Channel
MCS0 = -87 dBm to MCS9 (256QAM-5/6) = -64 dBm (per chain)
Nominal Receive Sensitivity (w/FEC) @80 MHz Channel
MCS0 = -84 dBm to MCS9 (256QAM-5/6) = -59 dBm (per chain)
Modulation Levels (Adaptive)
MCS0(BPSK)to MCS9 (256QAM5/6)
Transmit Power Range
0 to +29 dBm (combined, to regional EIRP limit) (1 dB interval)
Surge Suppression
1 Joule Integrated; Optional 30V Surge Suppressor (C000000L065A)
Environmental
IP67
Temperature
-22°F to +140°F (-30°C to +60°C)
Weight
0.46 kg (1.0 lbs.)
Wind Survival
180 km/hour (112 mi/hour)
