900 MHz PMP 450i Connectorized Subscriber Module
Specifications
SPECTRUM
Channel Spacing
g Configurable on 0.5 MHz increments
Frequency Range
902 - 928 MHz
Channel Width
5 MHz, 7 MHz, 10 MHz, 15 MHz or 20 MHz
INTERFACE
Physical Layer
2x2 MIMO OFDM
Ethernet Interfaced
100/1000BaseT, full duplex, rate auto negotiated, 802.3 compliant (SM is 10/100BaseT only)
Protocols Used
IPv4, UDP, TCP, IP, ICMP, Telnet, SNMP, HTTP, FTP
PERFORMANCE
Subscribers Per Sector
238
Maximum Deployment Range
Up to 120 miles (190 km)
GPS Synchronization
n Yes, via Autosync (CMM4 or UGPS)
SECURITY
Encryption
56-bit DES, FIPS-197 128-bit AES
PHYSICAL
Environmental
AP: IP 66, 67 SM: IP55
Weight
Access Point: 1.8 kg (4 lbs.) Subscriber Module: 0.45 kg (1 lb.)
Dimensions (h x w x d)
Access Point: 26 x 13.4 x 6.4 cm (10.3” x 5.3” x 3.3”) Subscriber Module: 30 x 9 x 5 cm (11” x 3.5” x 2”)
