Quick Look
The ePMP 1000 Reflector Dish is designed to provide additional system gain when used with the ePMP 1000 Integrated Antenna. It is built to the highest level of quality and reliability. The ePMP Integrated Radio is attached to the Reflector Dish via a specially designed mounting bracket that aligns the hardware to maximize system gain. The combined solution doubles the maximum range for LOS environments and enables connections to those hard to reach stations. As a result, connectivity is brought to more subscribers in a wider range without installing additional access points.
