ePMP 3000L
Cambium Networks’ ePMP™ product line has set the standard for high performance, scalability and reliability in harsh interference environments all at a compelling price. The ePMP 3000L is the third generation access point (AP) that carries on the interference tolerance mechanisms with an emphasis on high-performance in low-density point to multipoint sectors.
Where to Buy
Key Advantages
  • Checkmark MicroPOP Applications: ePMP 3000L is ideally suited for areas with low density or small numbers of subscribers. With support for narrow-band sectors and omnis, coverage can be added exactly where needed.
  • Checkmark Frequency Reuse: Supports GPS synchronization and SM Transmit power control to allow for frequency re-use.
  • Checkmark Unmatched Performance and Scalability: With the efficient Cambium Networks MAC protocol and advanced air-fairness scheduler the ePMP 3000L supports high performance and low consistent latency to subscribers.
Key Specifications
  • Checkmark 2X2 MIMO support with peak throughput of 600 Mbps
  • Checkmark 256QAM-5/6, 80 MHz support
  • Checkmark Supports a wide frequency range: 4910 to 5950 MHz
  • Checkmark Frequency re-use with GPS sync and interference mitigation
  • Checkmark Connectorized for use with sector antenna. Also compatible with RF Elements Twistport(tm) Adaptor for ePMP
  • Checkmark Cloud or on-premises network management with cnMaestro
ePMP 3000L
Specifications
Channel Spacing
Configurable on 5 MHz increments
Frequency Range
4910–5970 MHz (exact frequencies as allowed by local regulations)
Channel Width
20 | 40 | 80 MHz
MAC (Media Access Control) Layer
Cambium Proprietary
Physical Layer
2x2 MIMO/OFDM
ARQ
Yes
Nominal Receive Sensitivity (w/FEC) @20 MHz Channel
MCS0 = -89 dBm to MCS8 (256 QAM-3/4) = -66 dBm (per chain)
Nominal Receive Sensitivity (w/FEC) @40 MHz Channel
MCS0 = -87 dBm to MCS9 (256QAM-5/6) = -64 dBm (per chain)
Nominal Receive Sensitivity (w/FEC) @80 MHz Channel
MCS0 = -84 dBm to MCS9 (256QAM-5/6) = -59 dBm (per chain)
