Program Details
Thousands of WISP’s around the world have discovered the performance, scalability and affordability of the Cambium Networks access network portfolio. Now with the Bring A Friend WISP Referral program it is easier and more lucrative than ever for current WISPs using Cambium to tell their friends and peers about the investment protection and low total cost of ownership that is achievable.
If you are a current WISP using Cambium Networks access products in your network and refer a new WISP to your Cambium reseller you can receive free-of-charge equipment when the new WISP buys their first set of equipment.
In short, here’s how it works:
- Current WISP’s tell all their peers and colleagues in the WISP industry about the success they’ve had deploying Cambium Products.
- When one of these NEW WISP’s (new to Cambium) purchases and deploys their first Access Point (or 12 SM’s if deploying primarily PTP links), the referring WISP gets a free Access Point.
- For every new WISP using ePMP that you refer, you’ll get an ePMP 3000 with MU-MIMO Sector antenna at no charge.
- For every new WISP using PMP 450 that you refer, you’ll get a PMP 450i Access Point.
The New WISP also receives access to the Cambium Learning portal and a coupon for taking the ePMP or PMP certification test at no-charge.
Getting Started
For the Referring or Ambassador WISP: Register the new WISP referral by clicking here. You’ll need contact information for the new WISP along with your contact information. After registering, someone from Cambium will reach out to you with more details. After the new WISP gets their equipment up on the air running you’ll get your no-charge equipment when approved.
For the NEW WISP: You can also register the opportunity and make a note of who referred you. Then contact your Cambium Reseller who will help you get started with Cambium Networks products.
Disclaimer: The Bring a Friend New WISP Referral program is active now through the end of 2019 so act fast. All referrals must be registered on this webpage to be eligible for approval under the WISP referral program. Cambium reserves the right to approve or reject any request under this program at its own discretion. Cambium may terminate this program at any time without notice. All promotional products are subject to local duties, taxes, as applicable.
