ePMP Force 300-13L
5 GHz Subscriber Module
Wireless service providers and enterprises around the globe are challenged to deliver reliable connectivity in overcrowded RF environments. As spectrum becomes an increasingly scarce commodity, finding the right broadband connectivity solution is vital for all low- and high-density deployments.
Force 300-13L is not available in the United States, Canada or anywhere that falls under FCC jurisdiction.
For product documentation, log in to Cambium Support.
ePMP Force 300-13L 5 GHz Subscriber Module
Specifications
Channel Spacing
Configurable on 5 MHz increments
Frequency Range
4920- 5970 MHz
Channel Width
10 | 20 | 40 | 80 | MHz
MAC (Media Access Control) Layer
Cambium Proprietary
Physical Layer
2X2 MIMO/OFDM
Ethernet Interfaced
10/100/1000 BaseT
Protocols Used
IPv4, IPv6, UDP, TCP, IP, ICMP, SNMPv2c, HTTPS, STP, SSH, 24V POE, IGMP Snooping
Network Management
HTTPS, SNMPv2c, SSH
VLAN
802.1Q with 802.1p priority
Antenna
Integrated dual-polarity 9 dBi omni-directional antenna
Transmit Power Range
0 to +29 dBm (combined, to regional EIRP limit) (1 dB interval)
