ePMP 2000 System
Specifications
SPECTRUM
Channel Spacing
Configurable on 5 MHz increments
Frequency Range
5150 - 5970 MHz (exact frequencies as allowed by local regulations)
Channel Width
5 I 10 I 20 I 40 MHz
INTERFACE
Physical Layer
2x2 MIMO/OFDM
Ethernet Interfaced
100/lOOOBaseT, rate auto negotiated, 802.3at compliant
VLAN
802.lQ with 802.lp priority
PERFORMANCE
Subscribers per Sector
Up to 120; Lite version limited to 10
GPS Synchronization
Yes, via internal GPS or CMM4 with 56 V and 5 pin to 7 pin cross over cable adapter
Quality of Service
Three-level priority (Voice, High, Low) with packet classification by DSCP, COS, VLAN ID, IP & MAC Address, Broadcast, Multicast, and Station Priority
PHYSICAL
Environmental
IP55
Weight
0.79 kg (1.5lbs) without brackets
Dimensions (Dia x Depth)
22.2 x 12.4 x 4.5 cm (8.75 x 4.9 x 1.75 in) without brackets
SECURITY
Encryption
128 bit AES (CCMP mode)
arrowsArtboard 1awardArtboard 1bar-chartArtboard 1cogArtboard 1caret-downcontactArtboard 1videoArtboard 1contactArtboard 2designArtboard 1cogArtboard 1videoArtboard 1open-faqArtboard 2videoArtboard 2arrowsArtboard 2arrowsArtboard 3listArtboard 1location-markerArtboard 1media-radioArtboard 1paperArtboard 1videoArtboard 1play-arrowArtboard 2arrow-rightArtboard 1arrow-rightArtboard 1sitemapArtboard 1tech-mobileArtboard 1tech-tabletArtboard 1uiArtboard 1videoArtboard 2video-playArtboard 2videoArtboard 1WordlMap Where to Buy
