The ePMP™ Smart Antenna enables smart beamforming; part of the innovative Hypure technology powering ePMP 2000 and 3000 designed from the ground up to help real-world networks overcome powerful interference and maintain excellent performance.
ePMP Smart Antenna
Specifications
Frequency Range
5150 – 5970 MHz (exact frequencies as allowed by local regulations)
Connectors to Access Point
2 x 50 ohm, RP (Reverse Polarity) SMA, DC Coupled (powering antenna)
Physical Dimensions
13.1" (L) x 8.4" (W) x 1.8” (H) (33.3 cm x 21.3 cm x 4.6 cm) Without Mounting Brackets
Weight
3.2 lbs. (1.5 kg) Without Mounting Brackets
Environmental
IP65
