ePMP™ 1000 PTP
Wireless service providers and enterprises need reliable, high-quality broadband connectivity that can be rapidly deployed and expanded. The ePMP platform provides stable coverage across large service areas and enhances your existing infrastructure.
Request A Quote
The Standard in Wireless Broadband
ePMP backhaul solutions provide low-latency, interference-tolerant, high-throughput options at very competitive prices. Supporting various channel bandwidths, ePMP suits a wide range of performance needs for different applications.
GPS-synchronized options allow more efficient use of spectrum by allowing synchronization of not only multiple backhaul links, but also a single backhaul to an ePMP Access Network. ePMP backhaul products are offered in the 5GHz and 2.4GHz bands with numerous configuration options, from simple integrated solutions to higher gain dish options.
Download the PTP Brochure
Features
GPS Synchronization
ePMP’s timing synchronization to the GPS pulse allows for extensive frequency reuse.
Security
128-bit AES encryption, L2 and L3 firewall rules, different user level support, HTTPs/SSH support provides enhanced security
Flexible Modes of Operation
Provides extremely low latency for PTP deployments, highly scalable mode without GPS sync and TDD operation for synchronized towers
Rugged Design
Operates in ambient temperatures as high as 60 degrees and as low as -30 degrees Centigrade.
Force 180
5
GHz
 200
Mbps
 20
Km
 16
dBi
The ePMP Force 180 5 GHz subscriber module is the next generation of the ePMP 5 GHz Integrated Radio offering a higher-gain, integrated 16 dBi patch antenna.
Force 200 5 GHz
5
GHz
 200
Mbps
 25
dBi
The ePMP Force 200 adds a subscriber module and point-to-point (PTP) radio to ePMP’s 5 GHz line of products, designed to operate in high interference environments and provide superior throughput of over 200 Mbps of real user data. Long range deployment is enabled by the 25 dBi antenna. Configurable Modes of operation ensure robust adaptivity to both symmetrical and asymmetrical traffic while providing high performance and round-trip latency as low as 2 – 3 ms.
Force 110 PTP
5
GHz
 220
Mbps
 40+
km
The ePMP Force 110 PTP high gain integrated solution enhances range (25 dBi antenna with 30 dBm of transmit power) and improves throughput (up to 200 Mbps of real user data) in high interference environments. Force 110 PTP acheives 2 ms of round-trip latency and provides a 802.3af compliant Gigabit Ethernet port. Comprised of the ePMP 1000 Connectorized Synchronized Radio and the ePMP110A-525 Dish.
Force 110
5
GHz
 150
Mbps
 40+
km
The ePMP Force 110 high gain integrated solution enhances range (25 dBi antenna with 30 dBm of transmit power) and improves throughput (up to 150 Mbps of real user data) in high interference environments. The Flexible Mode of operation ensures robust adaptivity to both symmetrical and asymmetrical traffic while providing high performance and exceptionally low 6 ms latency. ePMP Force 110 is comprised of ePMP 1000 Connectorized Radio and ePMP 110A-525 Dish.
Integrated Radio
2.4
GHz
 5
GHz
 150
Mbps
 15+
km
The ePMP 1000 Integrated Radio can be configured as a Subscriber Module, an unsynchronized Access Point or a Backhaul radio. This radio will function as a client (slave) to an ePMP GPS Synchronized Radio in either a PMP or PTP deployment forming a GPS Synchronized solution.
Connectorized Radio
2.4
GHz
 5
GHz
 150
Mbps
The ePMP 1000 Connectorized Radio has the flexibility to connect to a variety of external antennas such as 90 and 120 degree sector, omni and high-gain panel or dish antennas. This versatility allows service providers to configure their network using high gain antennas to satisfy the most challenging environments. The ePMP 1000 Connectorized Radio can be configured as a Subscriber Module, an unsynchronized Access Point or a Backhaul radio. This radio will function as a client (slave) to an ePMP GPS Synchronized Radio in either a PMP or PTP deployment forming a GPS Synchronized solution.
GPS Sync Radio
2.4
GHz
 5
GHz
 200
Mbps
Utilizing GPS sync, the ePMP is an ideal fit for networks that require capacity and reliability for superior QoS in remote and underserved areas. This integrated PTP and PMP solution features an efficient GPS synchronized operational mode that permits highly scalable frequency reuse. When deployed with a sector antenna, the radio can be configured as a GPS Synchronized Access Point serving ePMP Integrated Radios configured as Subscriber Modules. When deployed with a high gain point to point antenna, the ePMP GPS Sync Radio can be configured to be a GPS Synchronized Backhaul Master, forming a PTP link with another ePMP Radio module.
