cnWave 60 GHz
The V1000 Client Node is featured with wide-range, 80º beamforming for easy installation. Powered by 802.3af PoE, V1000 supports up to 2 Gbps with 1 Gbps in the uplink direction and 1 Gbps in the downlink direction.
The cnWave 60 GHz V2000 client node features a 2.5 GbE PoE input port as well as a 2.5 GbE PoE 802.3at output port for powering Wi-Fi access points or video surveillance cameras. This makes the V2000 especially well-suited to backhaul Cambium’s XV2 series of outdoor Wi-Fi AP’s.
Find out how to get a cnWave Starter Kit at a great low price! Extend the Network with Wireless Cambium Networks’ 60 GHz cnWave solution provides easy, fast and cost-effective wireless gigabit connectivity for edge access and/or high-capacity Wi-Fi backhaul for edge access solutions at a significantly lower TCO than fiber infrastructure. Service providers and…
Sub 6 High Capacity Backhaul
Field proven high reliable backhaul for small cell and critical infrastructure
The PTP 45700 Beam Steering ODU with integrated Smart Antenna provides electronic beamforming that allows for easy tactical installation and best-in-class interference mitigation in addition to the industry-leading spectral efficiency and processing capabilities of the PTP 700 family of products.
Licensed Microwave Backhaul
PTP 850C is next generation all-outdoor, multi-core unit. The PTP 850C has dual-core functionality enabling the system to operate up to 4 Gbps and deliver gigabit-plus capacity.
PMP 450 Backhaul family
Backhaul links are the vital infrastructure that connects the network. You need confidence that your solution will work under heavy demand, regardless of the conditions. Licensed and unlicensed point-to-point (PTP) solutions from Cambium Networks perform reliably so that you can focus on your business. The PTP 450b features up to 300 Mbps in a 40 MHz channel. Frequency range is 4.9 – 5.925 GHz.
Up to 300 Mbps in a 40 MHz channel. Frequency range is 4.9 – 5.925 GHz
Fit to comprehensive network with dynamic interference filtering
Both the 2x2 PTP 450v and 4x4 PTP 450v support up to 2x40 MHz of operating spectrum to deliver over 500 Mbps of data.
ePMP Backhaul Family
Combining the latest 802.llac Wave 2 technology and the field proven scalable performance of ePMP, the Force 300-19R delivers up to 600 Mbps of capacity. The Force 300-19R is a powerful yet affordable subscriber module compatible with the ePMP3000 Access Point and using the forward compatibility features also interoperates with the ePMP 2000 to ease the migration into the 802.llac Wave 2 technology. The Force 300-19R has a 19 dbi integrated antenna with a narrow beamwidth and reliable IP67 mechanics.
Cambium Networks’ ePMP Force 300-25 is designed to operate in high interference environments and provides superior throughput of over 500 Mbps of real user data.
Tower Switches
104 Gbps throughput, 8 PoE+ enabled ports, 8 10/100/1000 Mbps ports, 4 SFP+ Uplink ports
112 Gbps throughput, 16 PoE+ enabled parts, 16 10/100/1000 Mbps ports, 4 SFP+ Uplink ports
Feature Comparison |
ATTRIBUTES |
cnWave v3000 |
ePMP Force 425 |
ePMP F300 |
450b |
PTP 550 |
PTP 670 |
| Max Throughput (up to) | 3.6 Gbps | 1.0 Gbps | 600 Mbps | 300 Mbps | 1.44 Gbps | 450 Mbps |
| Spectrum Efficiency (bits/HZ/s) | 1.67 | 12.5 | 7.5 | 7.5 | 9 | 10 |
| Frequency Range (GHz) | 57 to 66 | 4.910 to 6.135 | 4.9 to 5.9 | 4.9 to 5.9 | 5.1 – 5.9 | 4.9 to 6 |
| Channel BW MHz | 2.16 GHz | 20/40/80 | 20/40/80 | 5/10/15/20/30/40 | 2x 20/40/80 | 5/10/15/20/30/40/45 |
| Channel bonding | Roadmap | No | No | No | Yes | No |
| Top Modulation | 16 QAM | 1024 QAM | 256 QAM | 256 QAM | 256 QAM | 256 QAM |
| Packets Processed per Second | 80,000 | 80,000 | 50,000 | 120,000 | 850,000 | |
| Integrated Antenna | 40.5 or 44.5 dBi | 25 dBi | 13/16/19/25 dBi | 17/24 dBi | 23 dBi | 23 dBi |
| Latency | < 1 ms | 3-6 ms | 3-6 ms | 3-5 ms | 3-6 ms | 1-3 ms |
| Tx Power | 19 dBm beam-forming | 28 dBm | 27 dBm | 27 dBm | 26 dBm | 27 dBm |
| Jumbo Frame | 4000 bytes | 1700 bytes | 1700 Bytes | 1700 Bytes | 1700 Bytes | 9600 Bytes |
| Online Spectrum Analyzer | No | Yes | Yes | Standby | Yes | Yes |
| DSO | No | No | No | No | No | Yes |
| Encryption | 128 AES | 128 AES | 128 AES | 128 AES | 128 AES | 128 & 256 AES |
| 1588 Timing & SyncE | 1588 (Roadmap) | No | No | No | No | Yes |
| QOS | 4 level | 3 level | 3 Level | 4 Level | 3 Level | 8 Levels |
| PoE output | Yes | No | No | No | No | Yes |
| SFP Fiber Port | Yes | Yes | No | No | Yes | Yes |
| TDD Sync | Yes | No | Yes | Yes | Yes | Yes |
| TDM T1/E1 | No | No | No | No | No | Yes |
| IP Rating | IP67 | IP67 | IP55 (F300-19R=IP67) | IP67 | IP67 | IP67 |
| Power Consumption | 30 W | 28 W | 12 W | 12 W | < 30 W | <30 W |
Upcoming Events
Learning Opportunities
Discover ideas, tips, techniques, and insights that will help you improve skills, develop new expertise, and stay on the cutting edge of knowledge to maximize your Cambium solution investment.
Documentation
- 4.4–5.9 GHz Dual-Polarity Parabolic Antennas Data Sheet
- 4.4–5.9 / 7.1–8.5 GHz Tactical Parabolic Antennas Data Sheet
- 3-Ft Single-Pole Antenna Data Sheet
- 3-Ft Dual-Pole Antenna Data Sheet
- PTP 850GP Data Sheet
- PTP 700 Heavy Duty Mast System
- PTP 850EX-P Millimeter Wave Radio Data Sheet
- PTP 850CX Data Sheet
- PTP 820A Data Sheet
- N000000L054B: 240W Single Output Switching Power Supply
- PMP 450V 2×2 Fixed Wireless Subscriber Module and PTP Backhaul
- PTP 850EX Data Sheet
- 4.4 GHz – 5.9 GHz Collapsible Mesh Antenna Data Sheet
- PTP 550E Data Sheet
- PTP 550 Data Sheet
- 4.4–6.1 GHz 90-Degree Sector Antenna Data Sheet
- 4.4–6.05 GHz Dual-Polarization Omni-Directional Antenna Data Sheet
- PMP 450V 4×4 Fixed Wireless Subscriber Module and PTP Backhaul
- PTP 45700 Beam Steering ODU
- PTP 820G License Microwave Radio
- PTP 78700 Fixed Wireless Backhaul Data Sheet
- 7 and 8 GHz PTP 700 Ultra-Wideband Datasheet
- PTP 45700 Fixed Wireless Backhaul Data Sheet
- 2ft 5.25–5.85 GHz High-Performance Antenna
- Ruggedized Enhanced Power Injector (R-EPI) Data Sheet
- Tactical Deploy 90 (TD 90) Data Sheet
- PTP 450i
- PTP 850C Data Sheet
- 450b Retro Data Sheet
- LINKPlanner Data Sheet
- PTP 850E Data Sheet
- PTP 820 Network Management System
- PTP 820E Data Sheet
- cnPulse Data Sheet
- PTP 670 Data Sheet
- PTP 550
- Rugged Outdoor Cable
- PTP 820C HP Data Sheet
- PTP 820S FCC/IC 24 GHz Licensed Microwave Radio
- PTP 700 HCMP
- Intelligent Positioners Data Sheet
- 56v Gigabit Ethernet Surge Suppressor Data Sheet
- PTP 650 LPU
- PTP 820S Data Sheet
- Adoption and Benefits of Fixed Wireless Networks in Germany’s Chemical Industry
- Wi-Fi Without Limits: How Latrobe City Council Revolutionized Public Internet Access
- WiFi “end to end”para Glampings
- Conectividad de alta velocidad para prevenir y combatir incendios forestales
- Exceptional Holiday Park Wi-Fi on a Nationwide Scale
- Gulf of Suez Petroleum Company GUPCO Uses Expandable Secure Broadband Coverage in Remote Offshore Areas
- Khalda Petroleum Company: 13x Network Bandwidth Jump with Lower Costs
- Hybrid Wireless Balances connects remote Oil and Gas locations with fixed wireless and Wi-Fi
- La Scara, une coopérative céréalière haut débit !
- Multi-Billion Dollar Energy Producer Measurably Improves Safety and Efficiency with Centralized Wireless Connectivity – Future Technologies
- Personalized High-Bandwidth Wireless Connectivity Enables Water Management Communications
- Outdoor Wi-Fi 6 Provides End-to-End Connectivity for Olympic Trials in Oregon
- Municipal Network in Aurora, Colorado Goes Gigabit Speed
- Digital Oil Field Streamlines Telecommunications With Fixed Wireless Access
- YLess4U Improves Connectivity for Rural Australia
- HTSnet Increases Performance by 17% Through Dynamic Channel Selection Capabilities
- Maggioli SpA for Public Safety
- SACSM Industrial Connectivity
- CEMAFE
- WSP
- ORION Telekom
- Improving Water Utility Operations While Reducing Communications Costs – Aguakan
- Polk County, Florida
- South Asian Games
- HCSO Florida
- A New Wireless Broadband Link Record of 245 km
- Western Downs CCTV
- Telemar
- JAB Broadband PMP 450
- Cambium Networks Tactical Deployable Communications (TDC)
- PTP 700 Beam Steering
- Unrivaled Protection Starts with Unparalleled Connectivity
- Campus Area Network Multi-Gigabit Connectivity
- Multi-Gigabit Fixed Wireless Backhaul for Wi-Fi
- Unleashing Ultrahigh-Capacity Wireless Broadband With Cambium Networks’ 60 GHz Solution
- Frequently Asked Questions About the Implementation of cnWave
- 802.11ay Emerges as the New Standard for 60 GHz Wi-Fi
- Wireless Connectivity Enables Remote Education
- PTP 670 Synchronous Ethernet and IEEE1588 Primer
- PTP 550 for VoIP Applications
- Wireless Backhaul for LTE and Small Cell Networks
- Wireless Fabric with Intelligent Edge
- Disaster Recovery – Interview with Kix Internet
- Smart Highways Solution Paper
- The Wireless Niche in your Network
- Wireless Connectivity Solutions for Rail Efficiency and Safety
- Licensed Microwave Connectivity for Freight Rail
- Enabling Wireless IIoT Architecture
- Wireless Mining Operations
- PTP 670 HCMP Security
- Video Surveillance with HCMP
- My View – Eli Williamson
- Connecting Communities Huffington Post article
- My View – Royell Communications
- My View – Cyber broadcasting
- Office to Field Solution Paper
- QD Positioner Solution Paper
- Platform to Vessel Solution Paper
- ATEX HAZLOC Solution Paper
- Wireless Video Surveillance Solutions
- Reliable Backhaul with TDM Wireless
- Water Utilities Experiences
- Water Utilities Applications
- Private Wireless Networks for Utilities
- Electric Utilities Internet Service Provider
- Electric Utilities Field Area Networks ROI
- Electric Utilities Applications
- RADIUS
- High-Capacity Backhaul
- Dynamic Spectrum Optimization (DSO)
- Video Surveillance Linear Architecture
- PTP UC APL Certification
- Small Cell Backhaul
- PTP I3MP
- PTP FIPS 140-2
- PTP Border Security
- PTP Test Range
- PTP LMR
- Leased-Line Replacement
- Connecting Citizens
- ONE Network for Service Providers
- WLAN-Lösungen für das Gastgewerbe
- Cambium Networks Overview
- PTP Overview Brochure
- PTP 700 Brochure
- Traffic Control Brochure
- PTP 820 Brochure
- Events Connectivity Brochure
- Video Surveillance Backhaul Brochure
- Disaster Recovery Brochure
- Rural Connectivity Brochure
- Smart Highways Brochure
- Local Government Brochure
- Higher Education Brochure
- Wireless Connectivity for Mining Operations
- Wireless Connectivity Solutions for Mining
- Freight Rail Transportation
- Smart Cities Brochure
- Primary and Secondary Education Solutions
- IIoT Solutions Brochure
- Water Utilities
- PTP 850GP Installation Guide
- PTP 850E Technical Description
- PTP 850C Technical Description
- PTP 850C Installation Guide
- PTP 850CX Technical Description
- PTP 850CX Installation Guide
- PTP 820A Installation Guide
- PTP 820 RFU-SX Installation Guide
- PTP 820 RFU-D-HP Installation Guide
- SFP Guide
- PTP 850EX User Guide
- PTP 850EX Installation Guide
- PTP 850EX Technical Description
- cnMaestro Quick Start Guide
- PTP 550 Legal and Open Source Notice
- Power Accessories Guide
- PTP 700 Legal and Open Source Notice
- PTP 670 Legal and Open Source Notice
- PTP 850C / PTP 850E User Guide
- PTP 820C HP Installation Guide
- PTP 700 TD90 Series User Guide
- PTP 550 Quick Start Guide v4
- Intelligent Positioning System User Guide
- PTP 850 Series MIB Reference Guide
- PTP 820 Series MIB Reference Guide
- PTP 850E Installation Guide
- PTP 820E Installation Guide
- PTP 820S Installation Guide
- PTP 820 all outdoor User Guide
- PTP 700 Series User Guide
- Cambium PTP 700 Series Installation Guide
- PTP 670 Quick Start Guide
- PTP 550 Series User Guide
- PTP 670 Series Installation Guide
- PTP 670 Series User Guide
- PTP 650 LPU Installation Guide
Upgrade from PTP820C to PTP 850CX
Upgrade from PTP820S to PTP 850CX
Smart Wi-Fi Management: How Cambium’s MarketApps Are Changing the Game
Enhance Customer Satisfaction with Fixed Wireless Solutions
WISPAPALOOZA Open House and Highlights
cnWave: Delivering Gbps Services with Distributed Mesh Networking
Virtual ANZ & PI WISP Forum
LINKPlanner V5.4.3: 60 GHz cnWave Project Planning
Castle Rock Microwave Aurora Deployment Best Practices
60 GHz – Multi-Gigabit Fixed Wireless, Something for Everyone – Antony Holmes
Creating Gigabit Wireless Networks for Education Campuses
PTP 550 Unboxing and Mounting
Security and Wireless Broadband
How to Choose the Right PTP Solution
PTP 670 Introduction
Cambium Innovation and Connectivity
Eolo Italy
Cambium Networks Longest PTP Link
PTP 700
- Webinar Replay: What’s New & Upcoming for North America WISPs in Q3 2024
- GDS Solutions Overview
- Webinar Replay: Introducing the PTP 850EX E-Band Millimeter Wave Solution
- Top Ten Reasons WISPs Love Working with Cambium Networks
- Top 10 Reasons to Switch to Cambium Networks
- Soluciones Punto a Punto (PTP) Y Punto MultiPunto (PMP) de Cambium Networks con Inventario disponible!
- Point-to-Multipoint (PtMP) and Point-to-Point (PTP) fixed wireless solutions from Cambium Networks – Middle Easy & North Africa Time Zones
- Point-to-Multipoint (PtMP) and Point-to-Point (PTP) fixed wireless solutions from Cambium Networks – Asia Pacific Time Zones
Blog Posts
Wireless Takes Center Stage in a Tech-Neutral BEAD Landscape
The Department of Commerce’s decision to revamp the BEAD program is a turning point for broadband in the U.S. By eliminating constraints…
Cambium Networks Expands Outdoor Wireless Solutions for Campus and Public Networks with Trailblazing Wi-Fi 6 Performance and Range
Leader in outdoor wireless solutions announces new high efficiency Wi-Fi 6 access points shattering the conventional wisdom of Wi-Fi performance and range…
Hello G, Goodbye M
Gigabit connectivity scenarios have been unleashed from the lab environment and are proliferating in the field. Multi-gigabit wireless fiber solutions are delivering…
Join the Cambium Community
Visit Community Forum
