Discontinued
PTP 650
Reliable, high-capacity, point-to-point wireless broadband for the most difficult real-world situations
Service providers, government and public safety agencies, and critical infrastructure operators need to match growing demands for data, voice and video traffic. Providing high throughput in limited spectrum is the challenge.
For product documentation, log in to Cambium Support.
PTP 650
PTP 650 Features
Frequency availability
4.9 GHz to 6.05 GHz
Capacity
up to 450 Mbps
Latency
1 - 3 ms
Flexible channel width
5, 10, 15, 20, 30, 40, and 45 MHz channels
Modulation
256 QAM, Fast Adaptive Modulation,
Reliability
Dynamic Spectrum Optimization
Security
128/256-Bit AES Encryption, HTTPS/TLS and SNMPv3 management, RADIUS authentication, and configurable password rules.
Versatility
Easy to integrate layer 2 bridge implementation supports symmetric and asymmetric TDD operation, 1588v2, and Synchronous Ethernet precision timing and frequency.
Industry-leading performance
Cambium Networks leads the industry in spectral efficiency and performance with the Point-to-Point (PTP) 650 wireless backhaul. With up to 450 Mbps aggregate throughput in a 45 MHz channel, and operating from 4.9 to 6.05 GHz, PTP 650 systems let you reliably and securely handle today’s needs with scalability to meet future requirements.
Dynamic Spectrum Optimization™ (DSO)
A unique capability offered by Cambium Networks that enables optimization of link performance by automatically sampling and changing channels to avoid interference without affecting link service. See the DSO White Paper for full details.
PTP 650 PERFORMANCE GUARANTEE
The PTP 650 is the highest performing, most reliable sub-6 GHz PTP radio on the market, backed by a satisfaction guarantee. Customers can deploy a PTP 650 link with confidence that it will meet or exceed expectations, or be refunded in full.
PTP 650
Specifications
RF BANDS1
Wide-band operation 4.9 to 6.05 GHz (Allowable frequencies and bands are dictated by individual country regulations. The most common bands are listed here.) 4.940 – 4.990 GHZ (Public Safety) 5.15 – 5.25 GHZ 5.25 – 5.35 GHZ 5.470 – 5.725 GHZ 5.725 – 5.850 GHZ 5.825 – 6.050 GHZ
CHANNEL SIZES
5, 10, 15, 20, 30, 40, and 45 MHz channels Channel sizes depend on individual country regulations
SPECTRAL EFFICIENCY
10 bps/Hz maximum
CHANNEL SELECTION
By Dynamic Spectrum Optimization or manual intervention; automatic selection on start-up and continual self-optimization to avoid interference
MAXIMUM TRANSMIT POWER
Up to 27 dBm at BPSK; up to 23 dBm at 256 QAM
RANGE
Up to 124 miles (200 km)
SECURITY
FIPS-197 compliant 128/256-bit AES Encryption (optional) HTTPS and SNMPv33 Identity-based user accounts Configurable password rules User authentication and RADIUS support Event logging and management; optional logging via syslog Disaster recovery and vulnerability management
PROTOCOL
IEEE 802.3
USER DATA THROUGHPUT
Dynamically variable up to 450 Mbps Maximum conditions – 2x2, 45 MHz channel1 , 256 QAM Flexible spectral efficiency / capacity licensing model: Lite Capacity: Up to 125 Mbps Mid Capacity: Up to 250 Mbps Full Capacity: Up to 450 Mbps Also available with licenses limiting maximum channel bandwidth
LATENCY
1 – 3 ms one-direction latency
QoS
8 Queues
NETWORK MANAGEMENT
In-band and out-of-band management (OOBM)
SYSTEM MANAGEMENT
IIPv6/IPv4 dual-stack management support Web access via browser using HTTP or HTTPS/TLS3 SNMP v1, v2c and v3, MIB-II and proprietary PTP MIB Cambium Wireless Manager, WM 4.0/SP4 or higher Online spectrum analyzer (no impact on payload traffic or network operation)
DIMENSIONS
Integrated Outdoor Unit (ODU): Width 371mm (14.6”), Height 371mm (14.6”), Depth 81mm (3.2”) Connectorized ODU: Width 204mm (8.0”), Height 318mm (12.5”), Depth 90mm (3.5”)
WEIGHT
Integrated ODU: 4.1 kg (8.95 lbs) including bracket Connectorized ODU: 3.1 kg (6.8 lbs) including bracket
OPERATING TEMPERATURE
-40° to +140° F (-40° to +60° C), including solar radiation
DUST-WATER INTRUSION PROTECTION
IP66 and IP67
