Xirrus XH2-240 AP benefits
Extreme Durability
Designed with an IP67 rating, the XH2-240 can withstand extreme temperatures, rain, humidity, and dust as well as harsh manufacturing environments, thereby delivering the same reliable Wi-Fi service as indoors.
Flexibility with Performance
With up to 6.9Gbps Wi-Fi capacity, this AP delivers sizzling performance under the most demanding environments. A range of directional antennas enables coverage that can be highly customized for different location needs.
Simplified Access Mangement
EasyPass Access Services provides simple, secure Wi-Fi access for employees, self-provisioned guests, BYOD onboarding and IoT devices.
The XH2-240 is a high-performance Wi-Fi access point designed for harsh outdoor environments. It delivers ubiquitous mobile access with Wi-Fi capacity up to 6.9Gbps and supports the latest multi-user MIMO technology. Cold and heat aren’t a problem either, because the AP is rated for operation from -40°C to 55°C (-40°F to 131°F). Designed with a powerfully integrated controller, layer 7 application visibility and simple user access with EasyPass, the XH2-240 provides a seamless Wi-Fi solution for outdoor or extreme environments, including campuses, transportation hubs, concert fields, refrigeration/chiller rooms, and more.
Xirrus XH2-240 Wi-Fi Access Point
Specifications
Technical Specs
Supported Standards
802.11a/b/g/n/ac (Wave 2)
Radio Technology
4x4:4, 802.11ac Software Defined Radio Technology
Max Wi-Fi Bandwidth
6.9 Gbps
Max Associated Devices
512
Max Power Consumption
25.5W (802.3at PoE)
Configuration Specs
Chassis Dimensions
11.75” x 8.75” x 4.0”
Total Number of Radios
1 - 2.4GHz / 5GHz - software defined radio (802.11a/b/g/n/ac Wave 2) 1 – 5GHz (802.11a/n/ac Wave 2
MIMO Technology
MU MIMO: Up to 8 streams SU MIMO: Up to 8 streams
