XH2-120 AP provides measurable results that enhance Wi-Fi outdoors
Always reliable
Meet capacity demands anywhere with fast, reliable Wi-Fi. Xirrus outdoor APs deliver the same top 802.11ac Wi-Fi performance as indoors to support services including digital displays and guess access. Ideal for high capacity demands found on campuses, in public meeting spaces, resorts, industrial areas, and more.
Performance plus
With the push of a button Xirrus TurboXpress enhances Wi-Fi performance by five times when both radios are programmed to support 802.11ac. XH2 APs automatically adjust to each device’s capability for an optimal user experience every time.
Management made easy
Plug-and-play deployment along with zero-touch configuration lets administrators set up secure, reliable Wi-Fi service in minutes. Manage users, devices, applications, and traffic from the cloud or on premise using a single console.
Compare Xirrus Access Points
Reliable Wi-Fi for Ruggedized Outdoor Environment
This dual radio access point (AP) is designed for outdoor use and can take anything you throw at it—heat, humidity, wind, snow, dust, sand, and more.
With flexible mounting options to accommodate any location or structure and a variety of antennae to serve any application, you can deliver fast, reliable Gigbit Wi-Fi to your users in any environment. Choose from cloud-based or on-premise Xirrus Management Systems (XMS) with robust tools for managing users, devices, applications, and traffic. Great Wi-Fi meets the great outdoors.
Xirrus XH2-120 Wi-Fi Access Point
Specifications
Technical Specs
Supported Standards
802.11a/b/g/n/ac
Radio Technology
2x2 MIMO, 11ac, 867Mbps, 2 - Software Defined Radios
Max Wi-Fi Bandwidth
1.7 Gbps
Max Associated Devices
512
Max Power Consumption
25.5W (802.3 at PoE)
Configuration Specs
Chassis Dimensions
7.7” X 9.875” X 10.125”
Supported Standards
802.11a/b/g/n/ac
Total Number of Radios
2
Radio Type
2x2, 867Mbps
MIMO Technology
SU-MIMO
Maximum Wi-Fi Bandwidth
1.7Gbps
