Industry’s Only 4-Radio Access Point
Xirrus XD (extreme density) Wi-Fi access points (APs) deliver maximum performance in high-density environments like classrooms, auditoriums, libraries, and training centers.
Thousands of users connecting at once? With four integrated 802.11ac radios and high-gain directional antennas XD4 APs support four times more users while decreasing cost of ownership up to 50% compared with 2-radio solutions.
Choose from two models, 3×3 Wave 1 (1.3Gbps) and 4×4 Wave 2 (3.47Gbps) 802.11ac, and custom-build a system to meet your unique needs. We also offer deployments kits, enclosures, mounting options for easy installation, and other accessories.
Xirrus XD4 APs feature built-in wireless controller, firewall, and threat sensor, reducing equipment needs 75%. Choose cloud-based or on-premise network management and give IT administrators a full suite of tools to manage users, devices, applications, and traffic with complete visibility. Plus, the XD4 AP’s seamless scalability means you can upgrade your network more efficiently.
Xirrus XD4 APs delivers:
Unparalleled Performance
When it comes to high-density Wi-Fi the XD4 can’t be beat. Four integrated 802.11ac capable radios and automated RF configuration continually optimize performance. The XD platform automatically chooses the best available bands and power level without IT intervention. Plus, it customizes client connectivity for the best performance based on each device’s capability for a true zero-touch experience.
Best ROI
All XD APs feature TurboXpress, which allows administrators to configure every radio on the AP for high-speed 802.11ac operation with just one click, boosting Wi-Fi performance up to six times. It’s the only industry solution that can add wireless capacity instantly without adding APs. TurboXpress also enables you to effortlessly address changing needs, protecting your investment.
Xirrus XD4-240 Wi-Fi Access Point
Specifications
Technical Specs
Supported Standards
802.11a/b/g/n/ac (Wave 2)
Radio Technology
3x3 MIMO, 802.11ac, 1.3Gbps ; 4x4 MU-MIMO, 11ac, 3.47Gbps; 4 -Software Defined Radios
Max Wi-Fi Bandwidth
3x3 MIMO - 5.2Gbps / 4x4 MU-MIMO, - 13.8Gbps
Max Associated Devices
780
Max Power Consumption
4x4 - 46 W
Configuration Specs
Chassis Dimensions
10"
Supported Standards
802.11 a/b/g/n/ac (Wave 2)
Total Number of Radios
4 - 2.4GHz / 5GHz software defined radios
Radio Type
4x4 11ac 3.47Gbps
MIMO Technology
MU-MIMO: 16 Streams
Maximum Wi-Fi Bandwidth
13.88Gbps
