Meet today’s Wi-Fi demands and Prepare for the Future
Future Proof Platform
Support software-defined radios that enable dual 802.11ac radio operation for a long product lifespan and gradual migration to Wave 2 as clients come to market.
Industry-leading Efficiency
Multi-user MIMO (MU-MIMO) Wave 2 advancement enables multiple clients to communicate at once revolutionizing Wi-Fi operation and dramatically increasing efficiency.
Superior Speed
Create an unsurpassed user experience including mobile applications and IoT devices with up to twice the speed of other 802.11ac Wave 2 APs on the market.
Boost Wi-Fi performance and increase network efficiency with 802.11ac Wave 2 technology.
XD2 access points (APs) meet today’s BYOD and IoT demands with the capacity to keep up whenever needs change. Ideal for offices, classrooms, conference rooms, and other areas requiring robust connectivity, the XD2 delivers extreme performance even with high-bandwidth applications.
Manage and upgrade your network with ease—choose cloud-based or on-premise centralized network management. Customize installation through deployment kits, enclosures, and mounting options and build the system that works best for you.
Xirrus XD2-230 Wi-Fi Access Point
Specifications
Technical Specs
Supported Standards
802.11a/b/g/n/ac (Wave 2)
Radio Technology
3x3 MU-MIMO, 802.11ac, 2.6Gbps; 4X4 MU-MIMO, 802.11ac, 3.47Gbps; 2 -Software Defined Radios
Max Wi-Fi Bandwidth
3x3 MU-MIMO- 3.9Gbps / 4x4 MU-MIMO- 6.9Gbps
Max Associated Devices
480
Max Power Consumption
3x3 MU-MIMO - 20W (802.3at PoE) / 4x4 MU-MIMO - 24W (802.3at PoE)
