Cambium Mission    |    Community   |    Blog    |    Contact
LINKPlanner
supported products
Sub-6GHz Point to Point
PTP 700
PTP 650 / 650S / 650L
PTP 600
PTP 500
PTP 450
PTP 450i
PTP 250
ePMP
Licensed Point to Point
PTP 800
PTP 810
PTP 820
Point to Multipoint
PMP 450
PMP 450i
ePMP 1000*
*Coming Soon (Note:
ePMP 1000 5.9 GHz)
CAMBIUM LINKPLANNER
Designed for use with our point-to-point and point-to-multipoint solutions, LINKPlanner allows you to easily and quickly design networks for optimal deployment and cost effectiveness.
LINKPlanner allows you to conduct "what if" scenarios based on geography, distance, antenna height, transmit power, and other factors to optimize system performance before purchase.
Available for Microsoft® Windows® and Intel®-based Mac® systems, LINKPlanner is a free, easy to use link-design tool.
Get started today.
LINKPlanner continues to grow in popularity as the most trusted and intuitive RF link planning tool in the industry. Tens of thousands of links have been successfully deployed across the globe using the LINKPlanner.
  • Quick Start – Path profiles are automatically imported into LINKPlanner when you create a new link using the Path Profile Web Service.
  • Graphical Display – Optimize a link before deployment by changing input data to see the effect on performance and throughput. For example, if a link calculation indicates low throughput, then a number of factors (product type, frequency, channel bandwidth, antenna height, antenna size etc) can be changed to see the improvement on link performance.
  • Time-Saving Features – Easy-to-use pull-down menus cut learning time significantly and performance reports provide time-saving deployment guidelines. In addition, a single link or multiple links can be planned simultaneously.
  • Proposal Generation and Installation – LINKPlanner automatically generates bills of material, proposal reports and installation reports simplifying the deployment process.
