ePMP Bridge-in-a-Box
Plug-n-Play Outdoor Wireless Ethernet Bridge
PTP Wireless Bridge
ePMP Bridge-in-a-Box is a pre-paired Point-to-Point (PTP) link comprised of two ePMP Force 180 devices designed to extend networks between two locations (up to 10 miles apart).
ePMP Bridge-in-a-Box Features
Frequency
4910-5970 MHz
Throughput
up to 200 MBps
Flexible Channel Width
5, 10, 20, 40 MHz channels
Security
AES128 data encryption and RADIUS-based authentication
Extend a local network to a remote building
Extend your Wi-Fi link to a new location
Provide a cost-effective solution to backhauling CCTV networks
Support any application requiring network extension
What's in the Box
Force 180
200
Mbps
16
dBi
The ePMP Force 180 5 GHz subscriber module is the next generation of the ePMP 5 GHz Integrated Radio offering a higher-gain, integrated 16 dBi patch antenna. Installation and alignment are easy with the adjustable mounting bracket, and the Force 180 is small, sleek, and equipped with Gigabit Ethernet port to deliver the maximum throughput.
