ePMP™ 1000
ePMP™ 1000
The standard in wireless broadband
Wireless service providers and enterprises need reliable, high-quality broadband connectivity that can be rapidly deployed and expanded. The ePMP platform provides stable coverage across large service areas and enhances your existing infrastructure.
ePMP™ 1000 Features
GPS Synchronization
ePMP’s timing synchronization to the GPS pulse allows for extensive frequency reuse.
Scalability
Advanced, scalable scheduling mechanism supports up to 120 subscribers without degrading overall system performance.
Quality of Service
Powerful multi-level Prioritization Scheme that can be configured by the network operator to allow for the delivery of differentiated services.
Security
128-bit AES encryption, L2 and L3 firewall rules, different user level support, HTTPs/SSH support provides enhanced security.
Flexible Modes of Operation
Provides extremely low latency for PTP deployments, highly scalable mode without GPS sync and TDD operation for synchronized towers
Rugged Design
Operates in ambient temperatures as high as 60 degrees and as low as -30 degrees Centigrade.
Meet the ePMP product line
High throughput, diverse applications
Supporting 200+ Mbps throughput, the ePMP system solution provides triple-play voice, video and data services end-to-end in the most demanding networks, for an affordable price.
Long range
ePMP is optimized for outdoor applications, offering connectivity up to 40 miles with Cambium antenna accessories and further with higher gain products.
Spectral efficiency
Using the 2.4 GHz and 5 GHz frequency spectrum, the ePMP architecture covers major unlicensed global bands, making it the most effective connectivity solution for the world's under- and unconnected.
Powerful capabilities
ePMP 1000 features GPS Synchronization for seamless scalability and minimal self-interference, Quality of Service (QoS) ensures superior consistency and integrity for VoIP (Voice over IP), video and data services - all kept running reliably by rigorously field tested components that minimize service requirements and maximize performance.
ePMP 1000 product line
Force 180
5
GHz
200
Mbps
20
Km
16
dBi
The ePMP Force 180 5 GHz subscriber module is the next generation of the ePMP 5 GHz Integrated Radio offering a higher-gain, integrated 16 dBi patch antenna. Installation and alignment are easy with the adjustable mounting bracket, and the Force 180 is small, sleek, and equipped with Gigabit Ethernet port to deliver the maximum throughput.
Force 200 2.4 GHz
2.4
GHz
200
Mbps
40
km
17
dBi
The ePMP Force 200 adds a subscriber module and point-to-point (PTP) radio to ePMP’s 2.4 GHz line of products, designed to operate in high interference environments and provide superior throughput of over 200 Mbps of real user data. Long range deployment is enabled by the 17 dBi antenna combined with 30 dBm transmit power. Configurable Modes of operation ensure robust adaptivity to both symmetrical and asymmetrical traffic while providing high performance and round-trip latency as low as 2 – 3 ms.
Force 200 5 GHz
5
GHz
200
Mbps
25
dBi
The ePMP Force 200 adds a subscriber module and point-to-point (PTP) radio to ePMP’s 5 GHz line of products, designed to operate in high interference environments and provide superior throughput of over 200 Mbps of real user data. Long range deployment is enabled by the 25 dBi antenna. Configurable Modes of operation ensure robust adaptivity to both symmetrical and asymmetrical traffic while providing high performance and round-trip latency as low as 2 – 3 ms.
GPS Sync Radio
2.4
GHz
5
GHz
200
Mbps
Utilizing GPS sync, the ePMP is ideal for networks that require capacity and reliability for superior QoS in remote and underserved areas. This integrated PTP and PMP solution features an efficient GPS synchronized operational mode that permits highly scalable frequency reuse. When deployed with a sector antenna, the radio can be configured as a GPS Synchronized Access Point serving ePMP Integrated Radios configured as Subscriber Modules.
Integrated Radio
2.4
GHz
5
GHz
150
Mbps
15+
km
The ePMP 1000 Integrated Radio can be configured as a Subscriber Module, an unsynchronized Access Point, or a Backhaul radio. This radio will function as a client (slave) to an ePMP GPS Synchronized Radio in either a PMP or PTP deployment, forming a GPS Synchronized solution.
Connectorized Radio
2.4
GHz
5
GHz
150
Mbps
The ePMP 1000 Connectorized Radio has the flexibility to connect to a variety of external antennas such as 90 and 120 degree sector, omni, and high-gain panel or dish antennas. This versatility allows service providers to configure their network using high gain antennas to endure challenging environments. The ePMP 1000 Connectorized Radio can be configured as a Subscriber Module, an unsynchronized Access Point or a Backhaul radio. This radio will function as a client (slave) to an ePMP GPS Synchronized Radio in either a PMP or PTP deployment, forming a GPS Synchronized solution.The ePMP 1000 Connectorized Radio can be configured as a Subscriber Module, an unsynchronized Access Point or a Backhaul radio. This radio will function as a client (slave) to an ePMP GPS Synchronized Radio in either a PMP or PTP deployment forming a GPS Synchronized solution.
Force 110
5
GHz
150
Mbps Broadband
40+
km
The ePMP Force 110 high gain integrated solution enhances range (25 dBi antenna with 30 dBm of transmit power) and improves throughput (up to 150 Mbps of real user data) in high interference environments. The Flexible Mode of operation ensures robust adaptivity to both symmetrical and asymmetrical traffic while providing high performance and exceptionally low 6 ms latency. ePMP Force 110 is comprised of ePMP 1000 Connectorized Radio and ePMP 110A-525 Dish.
Force 110 PTP
5
GHz
220
Mbps
40+
km
The ePMP Force 110 PTP high gain integrated solution enhances range (25 dBi antenna with 30 dBm of transmit power) and improves throughput (up to 200 Mbps of real user data) in high interference environments. Force 110 PTP acheives 2 ms of round-trip latency and provides a 802.3af compliant Gigabit Ethernet port. Comprised of the ePMP 1000 Connectorized Synchronized Radio and the ePMP110A-525 Dish.
